Unable to upgrade from 0.97.2 to 0.99.3
19-09-25 22:12:57 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.99.3
19-09-25 22:12:57 INFO (SyncWorker_11) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.97.2 to homeassistant/raspberrypi3-homeassistant:0.99.3
19-09-25 22:12:57 INFO (SyncWorker_11) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.99.3.
19-09-25 22:23:30 ERROR (SyncWorker_11) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.99.3 -> 404 Client Error: Not Found (“no such image: homeassistant/raspberrypi3-homeassistant:0.99.3: No such image: homeassistant/raspberrypi3-homeassistant:0.99.3”).
19-09-25 22:23:30 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
19-09-25 22:23:30 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<process_lock..wrap_api() done, defined at /usr/src/hassio/hassio/utils/init.py:20> exception=HomeAssistantUpdateError()>
File “/usr/src/hassio/hassio/utils/init.py”, line 29, in wrap_api
return await method(api, *args, **kwargs)
File “/usr/src/hassio/hassio/homeassistant.py”, line 337, in update
raise HomeAssistantUpdateError()
hassio.exceptions.HomeAssistantUpdateError
