Unable to upgrade HA to Supervisor 2024.10.0?
Running on RPi
Core 2024.10.1
Supervisor 2024.09.1
Operating System 13.1
Frontend 20241002.2
An attempted GUI upgrade fails. Then, following the “unhealthy system pop-up” instructions, I get:
[core-ssh ~]$ ha supervisor update
Processing... Done.
Error: Abort update because of an issue with AppArmor: Can't fetch AppArmor profile https://version.home-assistant.io/apparmor_stable.txt: Timeout
[core-ssh ~]$
Any advice, welcome.
Hi Martin,
Are you running supervised installation or HAOS version of install?
Sorry…
But how do I tell?
Regards, M.
Is this the answer…?
System information
Version	core-2024.10.1
Installation type	Home Assistant OS
Development	false
Supervisor	true
Docker	true
User	root
Virtual environment	false
Python version	3.12.4
Operating system family	Linux
Operating system version	6.6.46-haos
CPU architecture	x86_64
Timezone	Europe/London
Configuration directory	/config
Try to reboot the Pi (not restart HA, full reboot)
Yep. Tried that. Many times…
See if you can reach this
Sorry. But can you offer some context?
I haven’t tried it, but I don’t think that that is a valid command to try on the HA CL.
Regards, M.
