"no such image: homeassistant/raspberrypi3-homeassistant:0.103.2: No such image: homeassistant/raspberrypi3-homeassistant:0.103.2"
I read in a topic it has something to do with the hassio-supervisor not having the right time, but as for as I can tell mine has the correct time. Last time after 20 times hitting the update button it finally worked.
For those who did update successfully, how long did it take? I’m running 0.100.3 on a Pi3B+. I’m trying to update to 0.103.2 as the others in this thread. I’m just trying to figure out how long it should take.
I’m getting the same error on a new install of 3.7. In my case all I see on the web UI is
Preparing Hass.io (this can take up to 20 minutes) I left it run overnight and the status remains the same.
This problem is has been driving me crazy for the past few days, but I just found the supervisor logs this morning. As far as I can tell my time is correct, although I can’t find any trace of ntp or chrony so I can’t vouch for the time being within milliseconds.
Interestingly enough, I pulled the container manually on the pi3 and it had no problem downloading it… so obviously the file is there. I did get an error saying /usr/local/lib/blah.blah.blah was full. I checked it out and the root volume is only 91M and 100% full. Kind of surprised /usr isn’t mounted as a separate partition.
I have the same issue… I tried to update lot of time without success
Following the log captured on the system window:
19-12-23 13:53:42 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.103.4
19-12-23 13:53:42 INFO (SyncWorker_9) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.102.1 to homeassistant/raspberrypi3-homeassistant:0.103.4
19-12-23 13:53:42 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.103.4.
19-12-23 13:57:39 ERROR (SyncWorker_9) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.103.4 -> 404 Client Error: Not Found (“no such image: homeassistant/raspberrypi3-homeassistant:0.103.4: No such image: homeassistant/raspberrypi3-homeassistant:0.103.4”).
19-12-23 13:57:39 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
This version wouldn’t work transparently with my 0.102.3 configs. It messed me up for a while because I was migrating hosts (from a PC to a Pi). I had just pulled “latest” in docker on the Pi and assumed everything would work. It was loading the person module and not showing any of my custom_components.mitsubishi_mqtt.
