I’m running Home Assistant Container on my Unraid server. No issues till upgrading to 2024.11, I can’t upgrade from 2024.10 to the latest release. It appears to be unhappy about one of my entity IDs being an email address. This seemed much different from the problem others have been having with this version. I thought the error was referencing a Google calendar that had the email address as the entity ID. I did add a different unique ID but that didn’t seem to resolve the issue. I tried enabling debug logging but I’m not getting any more useful information. I’m hoping someone could give some ideas of where to look next.
2024-11-16 18:52:40.397 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration weatheralerts which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.407 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration schlage which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.410 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nfl which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.412 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.416 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration spook_inverse which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.419 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration ui_lovelace_minimalist which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.421 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.424 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration frigate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.427 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.429 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration fontawesome which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:40.432 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-16 18:52:41.057 ERROR (MainThread) [root] Uncaught exception
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 687, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 157, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 326, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 458, in async_from_config_dict
await async_load_base_functionality(hass)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 427, in async_load_base_functionality
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1977, in async_initialize
entries[entry_id] = config_entry
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1618, in __setitem__
self.check_unique_id(entry)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1659, in check_unique_id
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The entry unique id ['[email protected]'] is not a string.
Thanks in advance for any help anyone can provide.
