I am getting the below error when trying to upload my changed code, also below:
Error:
INFO ESPHome 2023.8.0
INFO Reading configuration /config/esphome/sop-power-monitor.yaml...
WARNING GPIO0 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO4 is a Strapping PIN and should be avoided.
INFO Detected timezone 'Australia/Sydney'
ERROR Unexpected exception while reading configuration:
File "/usr/local/bin/esphome", line 33, in <module>
sys.exit(load_entry_point('esphome', 'console_scripts', 'esphome')())
File "/esphome/esphome/__main__.py", line 1023, in main
return run_esphome(sys.argv)
File "/esphome/esphome/__main__.py", line 1001, in run_esphome
config = read_config(dict(args.substitution) if args.substitution else {})
File "/esphome/esphome/config.py", line 986, in read_config
res = load_config(command_line_substitutions)
File "/esphome/esphome/config.py", line 840, in load_config
return _load_config(command_line_substitutions)
File "/esphome/esphome/config.py", line 828, in _load_config
result = validate_config(config, command_line_substitutions)
File "/esphome/esphome/config.py", line 756, in validate_config
result.run_validation_steps()
File "/esphome/esphome/config.py", line 125, in run_validation_steps
task.step.run(self)
File "/esphome/esphome/config.py", line 507, in run
validated = schema(self.conf)
File "/esphome/esphome/voluptuous_schema.py", line 34, in __call__
res = super().__call__(data)
File "/usr/local/lib/python3.9/dist-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.9/dist-packages/voluptuous/validators.py", line 229, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.9/dist-packages/voluptuous/validators.py", line 353, in _exec
v = func(path, v)
File "/usr/local/lib/python3.9/dist-packages/voluptuous/schema_builder.py", line 818, in validate_callable
return schema(data)
v = func(path, v)
File "/usr/local/lib/python3.9/dist-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/esphome/esphome/voluptuous_schema.py", line 148, in validate_mapping
cval = cvalue(key_path, value)
return schema(data)
return schema(data)
File "/esphome/esphome/components/image/__init__.py", line 174, in _file_schema
return validate_file_shorthand(value)
File "/esphome/esphome/components/image/__init__.py", line 130, in validate_file_shorthand
validate_cairosvg_installed(value)
File "/esphome/esphome/components/image/__init__.py", line 80, in validate_cairosvg_installed
import cairosvg
File "/usr/local/lib/python3.9/dist-packages/cairosvg/__init__.py", line 26, in <module>
from . import surface # noqa isort:skip
File "/usr/local/lib/python3.9/dist-packages/cairosvg/surface.py", line 9, in <module>
import cairocffi as cairo
File "/usr/local/lib/python3.9/dist-packages/cairocffi/__init__.py", line 47, in <module>
cairo = dlopen(
File "/usr/local/lib/python3.9/dist-packages/cairocffi/__init__.py", line 44, in dlopen
raise OSError(error_message) # pragma: no cover
OSError: no library called "cairo-2" was found
no library called "cairo" was found
no library called "libcairo-2" was found
cannot load library 'libcairo.so.2': libcairo.so.2: cannot open shared object file: No such file or directory. Additionally, ctypes.util.find_library() did not manage to locate a library called 'libcairo.so.2'
cannot load library 'libcairo.2.dylib': libcairo.2.dylib: cannot open shared object file: No such file or directory. Additionally, ctypes.util.find_library() did not manage to locate a library called 'libcairo.2.dylib'
cannot load library 'libcairo-2.dll': libcairo-2.dll: cannot open shared object file: No such file or directory. Additionally, ctypes.util.find_library() did not manage to locate a library called 'libcairo-2.dll'
Code:
esphome:
friendly_name: sop-power-monitor
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "XXX"
ota:
password: "XXX"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Sop-Power-Monitor"
password: "XXX"
captive_portal:
color:
- id: my_red
red: 100%
green: 0%
blue: 0%
- id: my_yellow
red: 100%
green: 100%
blue: 0%
- id: my_green
red: 0%
green: 100%
blue: 0%
- id: my_blue
red: 23.92%
green: 65.1%
blue: 84.71%
- id: my_gray
red: 50%
green: 50%
blue: 50%
binary_sensor:
- platform: status
- platform: gpio
pin:
number: GPIO0
inverted: true
mode:
input: true
pullup: true
name: "T-Display Button Input 0"
- platform: gpio
pin:
number: GPIO35
inverted: true
name: "T-Display Button Input 1"
# We can still control the backlight independently
switch:
- platform: gpio
pin: GPIO4
time:
- platform: homeassistant
spi:
clk_pin: GPIO18
mosi_pin: GPIO19
font:
- file: "gfonts://Audiowide"
image:
- file: "bck_gauge.png"
type: RGB24
- file: mdi:lan-connect
resize: 20x20
- file: mdi:wifi-remove
resize: 20x20
display:
- platform: st7789v
model: TTGO TDisplay 135x240
backlight_pin: GPIO4
cs_pin: GPIO5
dc_pin: GPIO16
reset_pin: GPIO23
rotation: 90
pages:
- id: home
lambda: |-
it.image(0, 0, id(background));
// Header
it.print(2, 5, id(audiowide_14), id(my_gray), TextAlign::TOP_LEFT, "Smart Power-meter");
it.strftime(215, 5, id(audiowide_14), id(my_gray), TextAlign::TOP_RIGHT, "%H:%M", id(esptime).now());
if (id(system_status).state) {
it.image(240, 5, id(connected), ImageAlign::TOP_RIGHT);
} else {
it.image(240, 5, id(disconnected), ImageAlign::TOP_RIGHT);
// Values of current and daily consumed power
it.printf(5, 50 + 5, id(audiowide_20), id(my_gray), TextAlign::TOP_LEFT, "%.1fW", id(current_power).state*1000.0);
it.printf(5, 80 + 5, id(audiowide_20), id(my_gray), TextAlign::TOP_LEFT, "%.2fkW/h", id(daily_power).state);
it.printf(5, 110 + 5, id(audiowide_20), id(my_gray), TextAlign::TOP_LEFT, "%.2fAUD", id(daily_cost).state);
// Real time consumption indicator
float pi = 3.141592653589793;
float alpha = 4.71238898038469; // Defined as the gauge angle in radians (270deg)
float beta = 2*pi - alpha;
int radius = 42; // Radius of the gauge in pixels
int thick = 7; // Size of the marker
int needle_radius= 9;
int min_range = 0;
int max_range = 10;
int xc = 180;
int yc = 85;
float measured = id(current_power).state;
if (measured < min_range) {
measured = min_range;
if (measured > max_range) {
measured = max_range;
float val = (measured - min_range) / abs(max_range - min_range) * alpha;
int xc0 = static_cast<int>(xc);
int yc0 = static_cast<int>(yc);
int x0 = static_cast<int>(xc + radius * cos(pi / 2 + beta / 2 + val));
int y0 = static_cast<int>(yc + radius * sin(pi / 2 + beta / 2 + val));
int x1 = static_cast<int>(xc + needle_radius * cos(pi / 2 + beta / 2 + val + 0.1));
int y1 = static_cast<int>(yc + needle_radius * sin(pi / 2 + beta / 2 + val + 0.1));
int x2 = static_cast<int>(xc + needle_radius * cos(pi / 2 + beta / 2 + val - 0.1));
int y2 = static_cast<int>(yc + needle_radius * sin(pi / 2 + beta / 2 + val - 0.1));
int x3 = static_cast<int>(xc + needle_radius * cos(pi / 2 + beta / 2 + val + 0.2));
int y3 = static_cast<int>(yc + needle_radius * sin(pi / 2 + beta / 2 + val + 0.2));
int x4 = static_cast<int>(xc + needle_radius * cos(pi / 2 + beta / 2 + val - 0.2));
int y4 = static_cast<int>(yc + needle_radius * sin(pi / 2 + beta / 2 + val - 0.2));
int x5 = static_cast<int>(xc + needle_radius * cos(pi / 2 + beta / 2 + val));
int y5 = static_cast<int>(yc + needle_radius * sin(pi / 2 + beta / 2 + val));
it.line(x0, y0, x1, y1, id(my_blue));
it.line(x0, y0, x2, y2, id(my_blue));
it.line(x0, y0, x3, y3, id(my_blue));
it.line(x0, y0, x4, y4, id(my_blue));
it.line(x0, y0, x5, y5, id(my_blue));
entity_id: sensor.total_daily_power_cost
- platform : homeassistant
entity_id: sensor.esp_ble_10_pzem_004t_pzem_004t_v3_voltage
entity_id: sensor.esp_ble_10_pzem_004t_pzem_004t_v3_power
# - platform: adc
# pin: A0
# id: LDR
# name: "LDR"
# update_interval: 5s
# on_value_range:
# - above: 0.1
# then:
# - switch.turn_on: backlight
# - below: 0.1
# then:
# - switch.turn_off: backlight
- platform: adc
pin: A3
attenuation: 11db
update_interval: 1s
- platform: adc
pin: A4
attenuation: 11db
update_interval: 1s
- platform: adc
pin: A5
attenuation: 11db
update_interval: 1s
- platform: ct_clamp
sensor: Input_1
sample_duration: 200ms
update_interval: 1s
filters:
- calibrate_linear:
- 0 -> 0
- 0.042 -> 2.72
sensor: Input_2
update_interval: 1s
filters:
- calibrate_linear:
- 0 -> 0
- 0.033 -> 1.07
sensor: Input_3
update_interval: 1s
filters:
- calibrate_linear:
- 0 -> 0
- 0.022 -> 0.66
- platform: total_daily_energy
name: "Total Daily Power"
power_id: current_power
# - platform: template
# id: current_power
# name: "Measured Power"
# lambda: return (id(Probe_1).state + id(Probe_2).state + id(Probe_3).state) * 230.0 / 1000; #Power = Current * Voltage
# unit_of_measurement: 'kW'
I have tried reading through but I cannot see what is wrong, can someone please assist me ?
Thank you
