Hi, I have DHT22 sensor running fine with the ESP32 board in ESPHome and today I want to calibrate it by adding the filters section into my config file and it passes the validation.
When I want to upload it wirelessly to the ESP32 board, it fails with the following error message.
Try to clean-compile → click on three dots (on home page of esphome addon), select “clean build files” and compile again.
As for esphome addon: you must add a repo: read this
I am having the same error. It happens when I try to upload to any of my ESP boards, even if I have not made any changes to the currently working code.
I’m suspecting the problem is due to old version of EPShome, though I have not tried again with the latest EPShome as I have not updated the ESPhome yet.
I have tried to clean the compile library as suggested by @Protoncek , but it didn’t help.
