Hey, just after some pointers to get bleak and dbus working within a python script I’m running out of appdaemon.
Setup is a RPI4 x64 - install was done through docker using the supervised install.
tried adding to the config:
init_commands: []
python_packages:
- bleak
system_packages:
- dbus
code snippets:
import bleak
from bleak import BleakScanner, BleakClient
devices = await BleakScanner.discover()
if not devices:
self.log("No devices found.")
return
# Print available devices
for i, device in enumerate(devices):
self.log("{}: {}".format(i, device))
Log is:
File "/usr/lib/python3.10/site-packages/appdaemon/threading.py", line 826, in async_worker
await funcref(
File "/config/appdaemon/apps/my_script.py", line 24, in button_callback
await self.run_script()
File "/config/appdaemon/apps/my_script.py", line 35, in run_script
File "/usr/lib/python3.10/site-packages/bleak/__init__.py", line 216, in discover
async with cls(**kwargs) as scanner:
File "/usr/lib/python3.10/site-packages/bleak/__init__.py", line 126, in __aenter__
await self._backend.start()
File "/usr/lib/python3.10/site-packages/bleak/backends/bluezdbus/scanner.py", line 174, in start
manager = await get_global_bluez_manager()
File "/usr/lib/python3.10/site-packages/bleak/backends/bluezdbus/manager.py", line 896, in get_global_bluez_manager
await instance.async_init()
File "/usr/lib/python3.10/site-packages/bleak/backends/bluezdbus/manager.py", line 190, in async_init
bus = MessageBus(bus_type=BusType.SYSTEM)
File "/usr/lib/python3.10/site-packages/dbus_fast/aio/message_bus.py", line 172, in __init__
super().__init__(bus_address, bus_type, ProxyObject, negotiate_unix_fd)
File "src/dbus_fast/message_bus.py", line 186, in dbus_fast.message_bus.BaseMessageBus.__init__
File "src/dbus_fast/message_bus.py", line 740, in dbus_fast.message_bus.BaseMessageBus._setup_socket
File "src/dbus_fast/message_bus.py", line 713, in dbus_fast.message_bus.BaseMessageBus._setup_socket
FileNotFoundError: [Errno 2] No such file or directory```
