After changing my router from an AirPort Extreme to an Edgerouter 12, I’m unable to use my external url (xxxxxxx.duckdns.org:444) in my own LAN.
Hassio generic install.
Normally this isn’t a big problem, I’m using iOS beta v2. So when I’m on my wifi it uses the internal url http://192.168.79.54:8123/lovelace/default_view
. But tts doesn’t work that way.
I 've set up 3 VLAN’s, one for pc’s and iPhones: switch0.69 - 192.168.69.1/24
, one for IOT: switch0.79 - 192.168.79.1/24
and one for guests: switch0.89 - 192.168.89.1/24
I’m using caddy as a proxy.
This is my caddyfile
xxxxxxxxxx.duckdns.org {
header / {
Strict-Transport-Security "max-age=31536000; includeSubdomains"
X-XSS-Protection "1; mode=block"
X-Content-Type-Options "nosniff"
X-Frame-Options "SAMEORIGIN"
Referrer-Policy "same-origin"
proxy / localhost:8123 {
websocket
transparent
These are my port-forwards in my router
And I have this in my firewall
I know this isn’t an HA-problem, but I hope someone can help me with this
If you have other questions, shoot…
You have port 444 not 443 in one of the shots but you should have 443 to 8123 too…
@DavidFW1960
where do you mean?
Firewall or port forwarding?
I’ve found it, after 2 days of
and locking myself out…
I’ve had to enable Hairpin NAT (NAT loopback) on my 2 VLAN’s to switch0.79
and switch0.69
leaving the port forwards and the firewall rules…
Ah I didn’t notice you are using Caddy… your screenshots showed you had Hairpin NAT enabled too… weird but sorry I didn’t look closer…
This is an old thread, but I’m a little lost with this and maybe someone can help.
I’m using an EdgeRouter X and my external address (DuckDNS via HA addon) works from outside my own network, but when inside, it seems to resolve to the EdgeRouter webinterface.
This is the port forwarding config in EdgeRouter:
port-forward {
auto-firewall enable
hairpin-nat enable
lan-interface switch0.50
rule 1 {
description HomeAssistant
forward-to {
address 10.0.50.12
port 8123
original-port 443
protocol tcp
wan-interface pppoe0
Do I need to add any other NAT rules for this to work?
I do have two AdGuard instances (one in HA, one on a separate Pi), those are the DNS servers for the switch0.50 VLAN. Maybe that causes an issue?
