Unable to use mac_address and lambda together
Hey Everyone,
Is this a bug or am I doing something wrong? Both of these actions work individually but when I try to do them together the compile error is:
Failed config
esp32_ble_tracker: [source /config/esphome/esphome-master.yaml:39]
  scan_parameters:
    duration: 60s
    active: False
  on_ble_advertise:
      Unable to find action with the name 'mac_address'.
esphome-master.yaml
esp32_ble_tracker:
  scan_parameters:
    duration: 60s
    active: false
  on_ble_advertise:
    - mac_address: EB:82:34:XX:XX:XX
      then:
        - lambda: |-
            std::string name = x.get_name();
            if (esphome::str_startswith(name, "level:")) {
              name.erase(0,7);
              std::string value = esphome::str_until(name.c_str(), ' ');
              id(propane_level_tank_1).publish_state(atof(value.c_str()));
    - lambda: |-
        parseAdvertisement(x);
I think you might either need to shuffle this in 4 spaces, or repeat the on_ble_advertise trigger?
- on_ble_advertise:
- on_ble_advertise:
Apparently you can’t do these together by design. Doesn’t sound like it will be a feature either.
