Hello
I’ve got the FireTV component running, pointed at my Fire Stick. I’m hoping to use this, combined with an ICMP Ping sensor, to tell if my TV non-smart is on or off, because the Fire Stick is powered from my TV’s USB port.
Anyway. If the Fire Stick is on when the HA boots, it’s connected and I can manipulate it to my hearts content.
But - as soon as the Fire Stick is turned off (with the TV), my HA does not see it even when it comes back on, and therefore I can not manipulate it any more.
The state is whatever it was when the Fire Stick was turned off, and I get the following error about once per minute:
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 221, in async_update_ha_state
await self.async_device_update()
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 349, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/media_player/firetv.py", line 105, in _adb_wrapper
returns = func(self, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/media_player/firetv.py", line 201, in update
if not self.firetv.screen_on:
File "/usr/local/lib/python3.6/site-packages/firetv/__init__.py", line 197, in screen_on
return self._dump_has('power', 'Display Power', 'state=ON')
File "/usr/local/lib/python3.6/site-packages/firetv/__init__.py", line 245, in _dump_has
return self._dump(service, grep=grep).strip().find(search) > -1
File "/usr/local/lib/python3.6/site-packages/firetv/__init__.py", line 234, in _dump
return self._adb.Shell('dumpsys {0} | grep "{1}"'.format(service, grep))
File "/usr/local/lib/python3.6/site-packages/adb/adb_commands.py", line 376, in Shell
timeout_ms=timeout_ms)
File "/usr/local/lib/python3.6/site-packages/adb/adb_protocol.py", line 411, in Command
return ''.join(cls.StreamingCommand(usb, service, command, timeout_ms))
File "/usr/local/lib/python3.6/site-packages/adb/adb_protocol.py", line 438, in StreamingCommand
File "/usr/local/lib/python3.6/site-packages/adb/adb_protocol.py", line 372, in Open
msg.Send(usb, timeout_ms)
File "/usr/local/lib/python3.6/site-packages/adb/adb_protocol.py", line 233, in Send
usb.BulkWrite(self.Pack(), timeout_ms)
File "/usr/local/lib/python3.6/site-packages/adb/common.py", line 332, in BulkWrite
return self._connection.send(data)
BrokenPipeError: [Errno 32] Broken pipe
This said, my ICMP ping sensor works very well at detecting when the Fire Stick is on or off. So my question is this:
Can I run an automation to “reset” or reload the FireTV component within HA without having to reboot it?
