Hello all,
everything was working well today untill I’ve rebooted the device, and now I cannot to use the zigbee lan
I have a sonoff dongle (e version)
Silicon Labs Multiprotocol version: 2.4.3
with the following configuration:
device: >-
/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230804082507-if00
baudrate: "460800"
flow_control: false
autoflash_firmware: false
cpcd_trace: false
otbr_enable: true
otbr_log_level: notice
otbr_firewall: true
and zigbee2mqtt
version: 1.35.1-1
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto:1883
user: mqtt-user
password: Y]VI6Z'<
serial:
port: tcp://core-silabs-multiprotocol:9999
adapter: ezsp
and when I star the z2m server I get the following error:
[21:59:02] INFO: Preparing to start...
[21:59:03] INFO: Socat not enabled
[21:59:06] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-01-11 21:59:15: Logging to console and directory: '/config/zigbee2mqtt/log/2024-01-11.21-59-15' filename: log.txt
Zigbee2MQTT:info 2024-01-11 21:59:15: Starting Zigbee2MQTT version 1.35.1 (commit #unknown)
Zigbee2MQTT:info 2024-01-11 21:59:15: Starting zigbee-herdsman (0.30.0)
Assertion failed: Command (setConfigurationValue) returned unexpected state: [object Object]
Assertion failed: Command (setValue) returned unexpected state: 55
Error: {"address":0,"clusterId":32770,"sequence":2} after 10000ms
at Timeout._onTimeout (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
at listOnTimeout (node:internal/timers:569:17)
at processTimers (node:internal/timers:512:7)
Does anybody has an idea how to fix it?
tnx
