Hi dear i’m on the latest versione 2021.1 and from already the previous version i cannot verify configuration in settings and also i can’t restart home assistant.
Here is the log. Some one can help me? Thanks
Dettagli registro (ERROR)
Logger: homeassistant.core
Source: helpers/config_validation.py:748
First occurred: 16:21:35 (1 occurrences)
Last logged: 16:21:35
Error executing service: <ServiceCall homeassistant.restart (c:ed3b10733839c962747f65b16bf8702a)>
File "/usr/src/homeassistant/homeassistant/core.py", line 1461, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 415, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 874, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 215, in async_check_ha_config_file
p_validated = platform_schema(p_validated)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 386, in validate_mapping
cval = cvalue(key_path, value)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 495, in verify
return cast(Dict, schema(value))
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 215, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 339, in _exec
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 748, in validator
if key in config:
TypeError: argument of type 'NoneType' is not iterable
