So i kinda gave up on the RSS feed as i can’t test it,
So i thought i’d curl the XML RSS feed and then use the new watch file feature in HASS. but i seem to be getting
2018-08-08 15:06:02 ERROR (MainThread) [homeassistant.loader] Unable to find component whitelist_external_dirs
2018-08-08 15:06:02 ERROR (MainThread) [homeassistant.setup] Setup failed for whitelist_external_dirs: Component not found.
My config is
whitelist_external_dirs: - /weather/weather.txt
output of ls -lsa from /
drwxrwxr-x 2 james james 4.0K Aug 8 15:13 weather
output of ls -lsa from /weather/
drwxrwxr-x 2 james james 4.0K Aug 8 15:13 .
drwxr-xr-x 24 root root 4.0K Aug 8 15:11 …
-rw-rw-r-- 1 james james 99 Aug 8 15:13 weather.txt
HASS is running as james
