I’ve a Raspi3, I was able to run the last upgrade of the Supervisor and also OS Upgrades, but I got stuck on the 2023.10.3
When I do the upgrade looks like it does a rollback and checking the logs seems is “cleared” because I cannot see events before / during the update process, the only relevant event I could see is
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:323
Integration: Recorder ([documentation](https://www.home-assistant.io/integrations/recorder), [issues](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+recorder%22))
First occurred: 19:43:41 (1 occurrences)
Last logged: 19:43:41
The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
Any idea why update is rollback ? please let me know if more details are needed so I could add it to the post.
