So I just swapped my hard drive, and restored my config using a snapshot.
Everything is back up and running, except the add-on store.
I have installed Home Assistant Supervised (Hass.io) on Ubuntu Server.
I have since updated to 107.7 with Supervisor 213.
This is how my add-on store looks like.
Nothing happens when I try to add the repository https://addons.community, except the log entry.
This is my system log:
Blockquote
20-03-29 14:12:18 WARNING (SyncWorker_3) [supervisor.docker.addon] Samba share run with disabled protected mode!
20-03-29 14:12:18 INFO (SyncWorker_0) [supervisor.docker.interface] Clean addon_core_ssh application
20-03-29 14:12:18 INFO (SyncWorker_3) [supervisor.docker.interface] Clean addon_core_samba application
20-03-29 14:12:18 INFO (SyncWorker_14) [supervisor.docker.addon] Start Docker add-on hassioaddons/ssh-amd64 with version 7.2.0
20-03-29 14:12:18 INFO (SyncWorker_13) [supervisor.docker.addon] Start Docker add-on hassioaddons/adguard-amd64 with version 2.3.1
20-03-29 14:12:18 INFO (SyncWorker_3) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-samba with version 9.0
20-03-29 14:12:19 INFO (SyncWorker_8) [supervisor.docker.addon] Start Docker add-on hassioaddons/portainer-amd64 with version 0.9.0
20-03-29 14:12:19 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_adguard
20-03-29 14:12:20 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_ssh
20-03-29 14:12:20 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_portainer
20-03-29 14:12:20 INFO (SyncWorker_0) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-ssh with version 6.0
20-03-29 14:12:21 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_portainer
20-03-29 14:12:21 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_adguard
20-03-29 14:12:25 INFO (SyncWorker_15) [supervisor.docker.interface] Start homeassistant/qemux86-64-homeassistant
20-03-29 14:12:51 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-03-29 14:12:51 INFO (MainThread) [supervisor.addons] Phase ‘application’ start 2 add-ons
20-03-29 14:12:51 INFO (SyncWorker_5) [supervisor.docker.interface] Clean addon_cebe7a76_hassio_google_drive_backup application
20-03-29 14:12:51 INFO (SyncWorker_10) [supervisor.docker.interface] Clean addon_core_configurator application
20-03-29 14:12:52 INFO (SyncWorker_5) [supervisor.docker.addon] Start Docker add-on sabeechen/hassio-google-drive-backup-amd64 with version 0.100.0
20-03-29 14:12:53 INFO (SyncWorker_10) [supervisor.docker.addon] Start Docker add-on homeassistant/amd64-addon-configurator with version 4.7
20-03-29 14:12:54 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-03-29 14:12:54 INFO (MainThread) [supervisor.api.security] /homeassistant/info access from cebe7a76_hassio_google_drive_backup
20-03-29 14:12:54 INFO (MainThread) [supervisor.api.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
20-03-29 14:12:54 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
20-03-29 14:12:54 INFO (MainThread) [supervisor.api.security] /snapshots/c855adfd/info access from cebe7a76_hassio_google_drive_backup
20-03-29 14:12:58 INFO (MainThread) [supervisor.tasks] All core tasks are scheduled
20-03-29 14:12:58 INFO (MainThread) [supervisor.hwmon] Started Supervisor hardware monitor
20-03-29 14:12:58 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-03-29 14:12:58 INFO (MainThread) [supervisor.host.info] Update local host information
20-03-29 14:12:58 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-03-29 14:12:58 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-03-29 14:12:58 INFO (MainThread) [supervisor.host.services] Update service information
20-03-29 14:12:58 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-03-29 14:12:58 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-03-29 14:12:58 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-03-29 14:12:58 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-03-29 14:14:22 INFO (SyncWorker_6) [supervisor.docker.interface] Restart homeassistant/qemux86-64-homeassistant
20-03-29 14:14:24 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-03-29 14:14:24 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-03-29 14:14:57 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-03-29 14:22:49 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - sabeechen/hassio-google-drive-backup: Automatically create and sync Home Assistant backups into Google Drive repository
20-03-29 14:22:49 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
20-03-29 14:22:49 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
20-03-29 14:22:51 INFO (MainThread) [supervisor.store] Load add-ons from store: 66 all - 0 new - 0 remove
20-03-29 14:26:29 INFO (MainThread) [supervisor.store.git] Remove custom add-on repository GitHub - hassio-addons/repository: Home Assistant Community Add-ons
20-03-29 14:26:29 INFO (MainThread) [supervisor.store] Load add-ons from store: 21 all - 0 new - 45 remove
20-03-29 14:26:31 INFO (MainThread) [supervisor.store.git] Clone add-on https://addons.community repository
20-03-29 14:26:32 ERROR (MainThread) [supervisor.store.git] Can’t clone https://addons.community repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://addons.community /data/addons/git/942cda15
stderr: 'Cloning into ‘/data/addons/git/942cda15’…
fatal: repository ‘https://addons.community/’ not found
20-03-29 14:26:32 ERROR (MainThread) [supervisor.store] Can’t load from repository https://addons.community
20-03-29 14:26:32 INFO (MainThread) [supervisor.store] Load add-ons from store: 21 all - 0 new - 0 remove
20-03-29 14:26:36 INFO (MainThread) [supervisor.store.git] Remove custom add-on repository GitHub - sabeechen/hassio-google-drive-backup: Automatically create and sync Home Assistant backups into Google Drive
20-03-29 14:26:36 INFO (MainThread) [supervisor.store] Load add-ons from store: 20 all - 0 new - 1 remove
20-03-29 14:26:38 INFO (MainThread) [supervisor.store.git] Clone add-on GitHub - sabeechen/hassio-google-drive-backup: Automatically create and sync Home Assistant backups into Google Drive repository
20-03-29 14:26:47 INFO (MainThread) [supervisor.store] Load add-ons from store: 21 all - 1 new - 0 remove
20-03-29 14:27:00 INFO (MainThread) [supervisor.store.git] Clone add-on https://addons.community repository
20-03-29 14:27:01 ERROR (MainThread) [supervisor.store.git] Can’t clone https://addons.community repository: Cmd(‘git’) failed due to: exit code(128)
20-03-29 14:27:01 ERROR (MainThread) [supervisor.store] Can’t load from repository https://addons.community
20-03-29 14:27:01 INFO (MainThread) [supervisor.store] Load add-ons from store: 21 all - 0 new - 0 remove
20-03-29 14:29:46 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
20-03-29 14:29:46 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - sabeechen/hassio-google-drive-backup: Automatically create and sync Home Assistant backups into Google Drive repository
20-03-29 14:29:48 INFO (MainThread) [supervisor.store] Load add-ons from store: 21 all - 0 new - 0 remove
20-03-29 14:31:19 INFO (MainThread) [supervisor.store.git] Clone add-on https://addons.community repository
20-03-29 14:31:19 ERROR (MainThread) [supervisor.store.git] Can’t clone https://addons.community repository: Cmd(‘git’) failed due to: exit code(128)
20-03-29 14:31:19 ERROR (MainThread) [supervisor.store] Can’t load from repository https://addons.community
20-03-29 14:31:19 INFO (MainThread) [supervisor.store] Load add-ons from store: 21 all - 0 new - 0 remove
20-03-29 14:38:39 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.107.7
20-03-29 14:38:39 INFO (SyncWorker_0) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.106.2 to homeassistant/qemux86-64-homeassistant:0.107.7
20-03-29 14:38:39 INFO (SyncWorker_0) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.107.7.
20-03-29 14:40:23 INFO (SyncWorker_0) [supervisor.docker.interface] Stop homeassistant application
20-03-29 14:41:23 INFO (SyncWorker_0) [supervisor.docker.interface] Clean homeassistant application
20-03-29 14:41:23 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-03-29 14:41:24 INFO (SyncWorker_3) [supervisor.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.107.7
20-03-29 14:41:33 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-03-29 14:41:33 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-03-29 14:41:34 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-03-29 14:42:24 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-03-29 14:42:29 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-03-29 14:42:29 INFO (MainThread) [supervisor.homeassistant] Successful run Home Assistant 0.107.7
20-03-29 14:42:29 INFO (SyncWorker_11) [supervisor.docker.interface] Cleanup images: [‘homeassistant/qemux86-64-homeassistant:0.106.2’]
20-03-29 14:43:39 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-03-29 14:43:48 INFO (MainThread) [supervisor.store.git] Clone add-on https://addons.community repository
20-03-29 14:43:49 ERROR (MainThread) [supervisor.store.git] Can’t clone https://addons.community repository: Cmd(‘git’) failed due to: exit code(128)
20-03-29 14:43:49 ERROR (MainThread) [supervisor.store] Can’t load from repository https://addons.community
20-03-29 14:43:49 INFO (MainThread) [supervisor.store] Load add-ons from store: 21 all - 0 new - 0 remove
The computer has a different IP now, perhaps thats causing this?
I use the Home Assistant Cloud service, if thats of relevance.
The only referance to the old IP i found in conf.yaml is this, which I updated to new IP.
Could it be something with my SSH (keys)?
