I´m really need a help, opened some threads about some of my problems including in github but noone was able to help me.
My cloud is not conecting to my google home, my darksky is not conecting and not showing in the fontpage, my spotfy not conecting as well, everything leads me to think it´s a connection problem, but when I tried to access for example the url from darksky directly from my computer I can, so it seems it´s a problem from hassio, or the HassOS or my docker, I really don´t know. Also I can´t update to 0.85
supervisor logs:
19-01-15 22:04:42 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-01-15 22:04:42 WARNING (MainThread) [hassio.api.proxy] Unauthorized WebSocket access
-01-16 13:19:44 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: Cannot connect to host s3.amazonaws.com:443 ssl:None [Try again]
19-01-16 13:24:51 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-01-16 13:21:58 WARNING (MainThread) [hassio.updater] Can't fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: Cannot connect to host s3.amazonaws.com:443 ssl:None [Try again]
one of my hassios logs
Unexpected error
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 97, in connect
yield from self._handle_connection()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 153, in _handle_connection
yield from hass.async_add_job(auth_api.check_token, self.cloud)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/auth_api.py", line 108, in check_token
if cognito.check_token():
File "/usr/local/lib/python3.6/site-packages/warrant/__init__.py", line 260, in check_token
self.renew_access_token()
File "/usr/local/lib/python3.6/site-packages/warrant/__init__.py", line 555, in renew_access_token
AuthParameters=auth_params,
File "/usr/local/lib/python3.6/site-packages/botocore/client.py", line 312, in _api_call
return self._make_api_call(operation_name, kwargs)
File "/usr/local/lib/python3.6/site-packages/botocore/client.py", line 592, in _make_api_call
operation_model, request_dict)
File "/usr/local/lib/python3.6/site-packages/botocore/endpoint.py", line 141, in make_request
Unable to connect to Dark Sky: HTTPSConnectionPool(host='api.darksky.net', port=443): Max retries exceeded with url: /forecast/b5dadd6836074028261ee0e4c44eb2fe/-23.5733,-46.6417?units=si&lang=en (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x728170d0>: Failed to establish a new connection: [Errno -3] Try again',))
hope someone could give me a light
