Unavailable Sensors Template Sensor
I’ve added a template sensor, courtesy of this webpage to list all entities reporting a state of unavailable, and it works as expected.
However, is there a way I can change the template sensor code to only list sensors that are unavailable, rather than having to edit a group, as this would need to be done every time a new device is added to HA, and I’m only interested in reporting sensors.
Template Sensor
  sensors:
    unavailable_entities:
      friendly_name: Unavailable Entities
      unit_of_measurement: entities
      icon_template: "{{ 'mdi:check-circle' if is_state('sensor.unavailable_entities','0') else 'mdi:alert-circle' }}"
      value_template: >
          {{ states|selectattr('state','in',['unavailable','unknown','none'])|rejectattr('domain','eq','group')
            |rejectattr('entity_id','in',state_attr('group.ignored_entities','entity_id'))|list|count }}
      attribute_templates:
        entities: >
                |rejectattr('entity_id','in',state_attr('group.ignored_entities','entity_id'))|map(attribute='entity_id')|list }}
Thanks @123 but I’ve made the amendments suggested and it returns unknown.
Below is my full sensor and I’ve tried it both including the last 4 lines and commenting them out and it still returns unknown
  sensors:
      value_template: >
              {{ states.sensor
                | selectattr('state', 'in', ['unavailable','unknown','none'])
                | map(attribute='entity_id') | list }}
        entities: >
Yes, this returns a number in Template Editor so I tried it in the dashboard card and it worked, so thank you.
I’ve changed it slightly because I want a list instead of a count and the below works
{{ states.sensor
          | map(attribute='name') | list }}
but is there a way of displaying a list of the devices that are unavailable or devices that have an unavailable entity instead of the individual entities?
So, the value_template works in the template editor but the sensor returns ‘Unknown’ when I use the below in markdown card.
Template Sensor:
  sensors:
      value_template: >
        {{ states.sensor
          | map(attribute='name')| list }}
Markdown card:
type: markdown
      content: >-
         {{ states('sensor.unavailable_entities')
            |replace(",","<br>")
            |replace("[","")
            |replace("]"," ")
            |replace("\x27","")
            |replace("\x22","")
It’s still returning unavailable.
I wasn’t aware of the Reload Templates requirement but I did that and it returned unavailable and the 2 below errors in the log:
Logger: homeassistant.components.sensor
Source: core.py:1225
Integration: Sensor (documentation, issues)
First occurred: 8:31:29 PM (4 occurrences)
Last logged: 8:34:59 PM
Error adding entities for domain sensor with platform template
Error while setting up template platform for sensor
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 455, in async_add_entities
    await asyncio.gather(*tasks)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 731, in _async_add_entity
    await entity.add_to_platform_finish()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 844, in add_to_platform_finish
    await self.async_added_to_hass()
  File "/usr/src/homeassistant/homeassistant/components/template/sensor.py", line 224, in async_added_to_hass
    await super().async_added_to_hass()
  File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 408, in async_added_to_hass
    await self._async_template_startup()
  File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 379, in _async_template_startup
    result_info.async_refresh()
  File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 953, in async_refresh
    self._refresh(None)
  File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1133, in _refresh
    self.hass.async_run_hass_job(self._job, event, updates)
  File "/usr/src/homeassistant/homeassistant/core.py", line 607, in async_run_hass_job
    hassjob.target(*args)
  File "/usr/src/homeassistant/homeassistant/helpers/template_entity.py", line 348, in _handle_results
    self.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 585, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 706, in _async_write_ha_state
    hass.states.async_set(entity_id, state, attr, self.force_update, self._context)
  File "/usr/src/homeassistant/homeassistant/core.py", line 1576, in async_set
    state = State(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1225, in __init__
    raise InvalidStateError(
homeassistant.exceptions.InvalidStateError: Invalid state encountered for entity ID: sensor.unavailable_entities. State max length is 255 characters.
First occurred: 8:31:30 PM (2 occurrences)
Last logged: 8:35:00 PM
Error doing job: Exception in callback None()
  File "/usr/local/lib/python3.10/asyncio/events.py", line 80, in _run
    self._context.run(self._callback, *self._args)
    state = State(
No, it didn’t but it all appears to be working correctly now as it’s showing all entities and no errors so some entities must have come back on line, I guess.
Is it possible, instead, to report the devices instead of the individual entities? This would make the list much easier to work with and readable in a dashboard card.
