Hello to all.
Yesterday i have changed my ISP. Everything was woring perfectly before the change. I did some port fowading on my router with the same configuration and here is the issue.
With a PC and using a web browser i can enter without problem with the local address 192.168.1.XX/8123 also i can connect via APP (on iOS and android) with the same address.
Here is the issue:
Using an external connection, i could connect without problem with the duckDNS domain: http://mydomain.duckdns.org:8123 via web browser (google chrome) on a PC and my phone. (note that i leave external and intenal port 8123 just like the same as my old config).
However when i try to connect via the Home Assistant App (on android and also iOS) it says “Unavaliable to connect to HA, could not find the hostname or proxy, use a valid URL of HA”
Is strange, using 4G connection (external) i could access via google chrome but not on the App, meaning that i have open the port correctly but there is an APP issue.
