Unavailable / Unknown Entity Monitoring - Template Sensor
I never did get around to resolving the duplicates. However, it looks like procrastination paid off because 0.104 has obviated the need for it. Nevertheless, I don’t wish to appear as a slacker so I offer you some minor streamlining.
According to my tests, you can replace this:
            |rejectattr('entity_id', 'in', state_attr('group.entity_blacklist', 'entity_id'))
            |rejectattr('entity_id', 'eq' , 'group.entity_blacklist')
with this:
            |reject('in', expand('group.entity_blacklist'))
            |reject('eq', states.group.entity_blacklist)
You can also remove this filter from the value_template:
map(attribute='entity_id')
Here’s the streamlined version:
    sensors:
      unavailable_entities:
        friendly_name: Unavailable Entities
        value_template: >
          {{states|selectattr('state', 'in', ['unavailable', 'unknown', 'none'])
            |list|length}}
        attribute_templates:
          entities: >
              |reject('eq' , states.group.entity_blacklist)
              |map(attribute='entity_id')|list|join(', ')}}
        unit_of_measurement: items
Thanks for putting this together, so does this streamlined version just replace the sensor section of @jazzyisj unavail_sensor.yaml? I’m not really certain what to change?
Where does this card get generated from? I don’t see anything in the github code for a lovelace card?
That is just one of my basic lovelace entities cards in my config. I’d have to go back through the thread to remember why it was referenced here. It has nothing to do with the unavailable entities sensor.
Not sure who you’re replying to but I think this was the final revised version of the sensor we came up with. Is this what you’re looking for?
EDIT: Updated version is always on the gist.
    sensors:
        entity_id: sensor.time
        icon_template: >
          {% if states('sensor.unavailable_entities')|int == 0 %} mdi:check-circle
          {% else %} mdi:alert-circle
          {% endif %}
        value_template: >
          {% set count = states|selectattr('state','in',['unavailable','unknown','none'])
            |rejectattr('entity_id','in',state_attr('group.ignored_sensors', 'entity_id'))
            |rejectattr('domain','eq','group')|list|length %}
          {{ count }}
          entities: >
            {% set entities = states|selectattr('state','in',['unavailable','unknown','none'])
              |rejectattr('entity_id', 'in', state_attr('group.ignored_sensors', 'entity_id'))
              |rejectattr('domain','eq','group')|list|join(', ') %}
            {{- entities -}}
@jazzyisj, thanks for providing the latest sensor for detecting unavailable entities! I’m trying to use this as a way of detecting when I’ve lost power and shut my instance of HA down gracefully to avoid data corruption. The problem I’m having is that the majority of my sensors are Z-wave dimmers (JASCO 28167) and even after 18 mins (and counting) after unplugging one of these devices, it’s still not showing as unavailable. It’s not in my ignored_sensors group. Any ideas on how to improve status reporting of the Z-wave hub (I’m using a GoControls HUSBZB-1)?
Using something like @ptdalen as shown below with polling intensity = 1 at least gets the device entity to show that the device is “Dead” pretty soon after unplugging it, but the status of the entity still shows blank as if the device is still available.
zwave:
  usb_path: /dev/ttyACM0
  config_path: /srv/homeassistant/src/python-openzwave/openzwave/config
  polling_interval: 10000
  customize:
    light.office_level_3_0:
      polling_intensity: 1
      refresh_value: 2
      delay: 3
Okay… I think I found the solution. Along with the polling intensity set to 1 as shown above, add the status of ‘dead’ to the states being checked for in to the sensor code @jazzisj provided directly above my remarks.
I’ve been trying to get this to work for 2 weeks with no success. I have Zigbee contact sensors that report as unavailable but the script never notify’s me. Can you test it with a zigbee device?
@mboarman: when you say that your zigbee contact sensors “report as unavailable”, do you mean that you are using the sensor provided by jazzyisj and the the sensor is reporting your zigbee contact sensors as unavailable? If so, not sure how my testing is going to help. I’ve got a zigbee contact sensor, so I can test for you in the next day or so, but need you to confirm what you mean by yours is “reporting as unavailable.”
@chad01 Sorry I should have been more specific, I have a couple sensors that the battery has died and are reporting as unavailable to HA. I assumed when I installed this script I was hoping it would give me feedback on any sensors that went missing from the network or the battery has died. So far it hasn’t done either. Appreciate any help! Thanks!
I don’t know what you’re doing wrong, but that’s exactly what this sensor does.
That’s what I figured…I drop the following in as a package.The group is created, the automation are listed, and the sensors appear. So I’m not sure why it isn’t sending any notifications. Below is my package file:
## Sensor - Unavailable Sensors
## - state: number of unavailable sensors
## - attribute: sensor_names - comma separated list of unavailable sensor names
## - attribute: sensor_entities: - comma separated list of unavailable sensor entity id's
## - updates every minute (sensor.time)
## - sensor entity_id's in ignored_sensors are filtered from this sensor
## - group.ignored_sensors MUST exist even if empty for sensor template to render
    sensors:
        icon_template: >
          {% endif %}
        value_template: >
          {{ count }}
          entities: >
            {{- entities -}}
group:
  ignored_sensors:
    entities:
      - sensor.ssl_certificate_expiry
automation:
  - id: sensor_unavailable_notification
    alias: "Sensor Unavailable Notification"
    description: "Send notification when sensor goes offline."
      # run whenever unavailable sensors sensor state changes
      - platform: state
        entity_id: sensor.unavailable_entities
    condition:
      # only run if the number of unavailable sensors had gone up
      - condition: template
        value_template: "{{ trigger.to_state.state | int > trigger.from_state.state | int }}"
      # wait 30 seconds before rechecking sensor state
      - delay:
          seconds: 30
      # make sure the sensor is updated before we check the state
      - service: homeassistant.update_entity
      # only continue if current number of sensors is equal or more than the number when triggered
        value_template: "{{ states('sensor.unavailable_entities') | int >= trigger.to_state.state | int }} "
      # create a persistent notification
      - service: persistent_notification.create
        data_template:
          title: "Sensor Unavailable"
          message: "### Unavailable Sensors: {{ '\n' + state_attr('sensor.unavailable_entities','sensor_names').split(', ') | join('\n') }}"
          notification_id: 'sensor_alert'
      - data_template:
        service: notify.pushover
  - id: dismiss_sensor_unavailable_notification
    alias: "Dismiss Sensor Unavailable Notification"
      # run when there are no more unavailable
      - platform: numeric_state
        below: 1
      # dismiss the persistent notification
      - service: persistent_notification.dismiss
I take it you do have a time sensor defined somewhere?
Well that’s an interesting question. I’m still new to the HA world. I figured this was a plug and play implementation. What am I missing? lol
Without a time sensor your unavailable entities sensor has nothing to update with. This will update every minute.
I do now! :slight_smile:
@anon43302295 - Ok, so I configured a working “sensor.time” rebooted HA and confirmed it appeared in the developer tools “states” tab.
I figured now, all I had to do was disconnect one of my zigbee contact sensors and wait for the magic to happen. After removing the battery in a zigbee contact sensor and waiting an hour or so for it to show up as unavailable, I never received any notification from this automation/script?
What am I doing wrong?! I pulled up the “sensor.unavailable_entities” in the states tab and noticed it shows “62” as a value. Am I wrong in assuming this should only show the value of those sensors that are unavailable? Seems like it’s showing the value of all the sensors I have in HA.
Any help is appreciated. Thanks again!
Obviously without logging in to your system I don’t know exactly what’s going on, but I would go to the states page and type ‘unavailable’ in to the filter for the states column and see how many it brings back, and whether the list looks like the ‘entities’ attribute for your unavailable entities sensor.
I understand that, and appreciate the quick response. So as I drilled down on the 62 entities that were showing as unavailable or unknown. It seems like most of them weren’t sensors that I wanted this script to monitor (for example I have several Dark Sky sensors that were reporting as unavailable). So I added all these to the ignored group and restarted home assistant and narrowed it down to 4 sensors (all of which should have been unavailable).
So now that piece of the puzzle makes sense. I just can’t figure out why the automation isn’t triggering a notification?
automation:
      - platform: state
    condition:
      - delay:
          seconds: 30
        data_template:
      - data_template:
