Unavailable / Unknown Entity Monitoring - Template Sensor
Check it is switched on, then go through each bit commenting them out until you get to the bottom of it, so like start with
  platform: state
  entity_id: sensor.unavailable_entities
  service: notify.pushover
  data_template:
    message: "{{ state_attr('sensor.unavailable_entities' , 'entities') }} are unavailable."
And take it from there.
Bear in mind that this will only trigger when the number changes, so if it’s already on 2 when it boots and it stays on 2 it won’t notify.
Ok…I’ve got everything finally working with some tweaks…Now I’m down to just one last issue. I have 4 group sensors that get flagged as ‘unavailable’ even though I have them listed on the blacklist. Is there any coding I can add to just ignore group sensors all together?
My sensor code:
    sensors:
      unavailable_entities:
        entity_id: sensor.time
        friendly_name: Unavailable Entities
        unit_of_measurement: items
        icon_template: >
          {% if states('sensor.unavailable_entities')|int == 0 %} mdi:check-circle
          {% else %} mdi:alert-circle
          {% endif %}
        value_template: >
          {{states|selectattr('state', 'in', ['unavailable','unknown','none'])
            |reject('in', expand('group.entity_blacklist'))
            |reject('eq', states.group.entity_blacklist)
            |list|length}}
        attribute_templates:
          entities: >
              |reject('eq' , states.group.entity_blacklist)
              |map(attribute='entity_id')|list|join(', ')}}
What’s a ‘group sensor’?
Did you mean group entities?
Sorry…Yes group entity is correct. For example the following entities get flagged as unavailable even though they are listed in the blacklist:
group.hsfansgroup
group.alextts
group.basementlights
Just looking for a way to exclude any “group” entities, since the individual ones would be flagged if they became unavailable.
I’m glad I found this thread. Got everything to work but it seems like it took about 2 hours for a zigbee sensor to report that it’s unavailable after I pulled the battery out to test. Any suggestions on how to make that wait a little shorter?
The problem with battery operated sensors is that they don’t keep a constant connection (thus extending the range of the battery).
You have to wait for whatever you’re using as a controller to ‘notice’ that it hasn’t updated in too long and then mark it as possibly absent. If this process takes 2 hours then there’s probably not much you can do.
Hey Mark,
Could you possibly share your full working code? I’ve got this deployed but not getting persistent or app notifications (badge working). The thread is so fragmented now, I don’t know which bits to include.
@mboarman did you figure out why your messaging wasn’t working? My notifications aren’t working because it looks like the data_template messaging. When I use the one listed here:
message: "### Unavailable Sensors: {{ '\n' + state_attr('sensor.unavailable_entities','sensor_names').split(', ') | join('\n') }}"
HA logs spits an error because sensor_names returns “None”. When I change it to:
message: "{{ state_attr('sensor.unavailable_entities' , 'entities' ) }} are unavailable."
the notification works, but the data in sensor.unavailable_entities shows something like this:
entities: >-
  <template state cover.garage_door=unavailable; restored=True, supported_features=3,
  device_class=garage, friendly_name=Garage Door @
  2020-07-01T21:52:56.277394-04:00>
Any idea how I can extract the “friendly_name” field?
@xbmcnut @ciscojunkie
After a lot of tweaking here is the package code I managed to get working. Seems to be pretty reliable on the latest builds. Note - I’m no YAML expert, a lot of trial and error with bits and pieces from this thread. Good luck!
    sensors:
        icon_template: >
          {% endif %}
        value_template: >
            |reject('eq', states.group.alexamailtts)
            |reject('eq', states.group.hsfangroup)
            |reject('eq', states.group.hslightgroup)
            |list|length}}
          entities: >
              |reject('eq' , states.group.alexamailtts)
              |reject('eq' , states.group.hsfangroup)
              |reject('eq' , states.group.hslightgroup)
group:
  entity_blacklist:
    entities:
      - sensor.ssl_certificate_expiry
      - binary_sensor.securifi_ltd_unk_model_3257780a_on_off
      - switch.dining_room_shuffle_switch
      - switch.echo_dot_bedroom_repeat_switch
      - switch.echo_dot_bedroom_shuffle_switch
      - sensor.dark_sky_icon
      - sensor.dark_sky_nearest_storm_distance
      - sensor.dark_sky_precip_probability
      - sensor.dark_sky_wind_bearing
      - sensor.dark_sky_wind_speed
      - weather.dark_sky
automation:
  - id: sensor_unavailable_notification
    alias: "Sensor Unavailable Notification"
    description: "Send notification when sensor goes offline."
      # run whenever unavailable sensors sensor state changes
      - platform: state
    condition:
      # only run if the number of unavailable sensors had gone up
      - condition: template
        value_template: "{{ trigger.to_state.state | int > trigger.from_state.state | int }}"
      # wait 30 seconds before rechecking sensor state
      - delay:
          seconds: 30
      # make sure the sensor is updated before we check the state
      - service: homeassistant.update_entity
      # only continue if current number of sensors is equal or more than the number when triggered
        value_template: "{{ states('sensor.unavailable_entities') | int >= trigger.to_state.state | int }} "
      # create a pushover notification
      - service: notify.pushover
        data_template:
          message: "Unavailable Sensors: {{ state_attr('sensor.unavailable_entities','entities').split(', ') | join('\n') }}"
Thanks @mboarman! I did (finally) figure it out, as well. I had to change the “states.sensor” to “states”, which did the trick. Guess I should have read the Templates documentation, since it clearly discourages that. :wink:
From (github)
        value_template: >
          {% set ignored_sensors = state_attr('group.ignored_sensors', 'entity_id') %}
          {% set unavail =  states.sensor | selectattr('state', 'eq', 'unavailable')
                                          | rejectattr('entity_id', 'in', ignored_sensors)
                                          | map(attribute='name')
                                          | list
                                          | length  %}
To:
        value_template: >
          {% set unavail =  states | selectattr('state', 'eq', 'unavailable')
                                          | list
                                          | length  %}
Question about integration… how do I save this in my system? I have it saved as unavailable_sensors.yaml. I presently don’t have a separate sensors.yaml, but if I do name it as such, I don’t think I can start it with sensor:, correct?
When triggering for in an Automation, what would my entity_id be?
It’s not an integration. It’s just a simple (kind of…) sensor.
I’m confused about what you are asking.
If you want to you can just put it into your configuration.yaml file under the “sensor:” section just like all of your other sensors.
if you do want to split it out using an !include then the text in the file can’t start with “sensor:”
Are you asking how to use the sensor in an automation?
the entity_id will be whatever you called it in the sensor config. Most likely if you just copied the code above it will be “sensor.unavailable_entities”.
If you are asking something else then you need to clarify what you mean.
Thank you.
I renamed my yaml to sensors.yaml, made the appropriate change in my config file.
In the sensors.yaml file, I started the entry as…
platform: template
sensors:
Here’s my Automation…
- id: '1595647471457'
  alias: Unavailable Sensor Alerts
  description: ''
  - above: '0'
    platform: numeric_state
  condition: []
  - data:
      message: "{%- for item in states -%}\n  {%- if is_state('item', 'unavailable')\
        \ -%} {{ item.attributes.friendly_name }} unavailable  {%- endif -%} A\n{%-\
        \ endfor -%}\n"
    service: notify.mobile_app_snote8
  mode: single
I’ll need to test this out.
Edit: I do receive the following logged error when restarting HA…
Error loading /config/configuration.yaml: in "/config/configuration.yaml", line 11, column 9: Unable to read file /config/sensors.yaml.
Line 11: sensor: !include sensors.yaml
I also have the following 2 ‘Property X is not allowed’ errors in the sensors.yaml file…
PROPERTY-ERRORS
Create a subdirectory in your main configuration directory named packages.
Add the following line to your configuration.yaml file (homeassistant: should already exist, it is just there to show you where to put the rest)
homeassistant:
  packages: !include_dir_named packages
Create a new file in the packages sub directory. Copy the entire contents of the file in this updated gist (make sure you copy the RAW text - look for the button) into your new file (I just posted and updated version). The file name does not matter but I would go with something like package_unavailable_entities_sensor.yaml .
Check your config and restart home assistant. You should now have a working sensor named sensor.unavailable_entities you can add to your front end and a couple of working sample automations. This is a good base to create your own automations to work with this sensor.
I’m curious what you mean by this? The only difference in the two examples in your code is the sensor will only look in the sensor domain for unavailable states while the second will look through every domain. This is perfectly acceptable and is actually documented on the Templating docs page.
This is not the same as the issue discussed in the warning box where the syntax used may result in an unknown state for the sensor. This sensor should always resolve to zero.
Thank you!
This is very helpful. Just what I was looking for to notify me when batteries go bad and devices become unavailable. Very useful.
Personally, I’d like to know about low batteries before they die. Here’s my solution for that. This isn’t anything I’ve really put out there, it’s pretty tailored to my config but it might give you some ideas how to handle it for yours. It creates a persistent notification and an alert push notification.
https://gist.github.com/jazzyisj/f7df28bd92298dc9e84d498da95425e4
While you’re at it you might like this custom lovelace plugin for battery entities.
Then there is this package, which to me just seems way overkill to me, but it is kinda neat!
Although everything seems to be configured as you’ve stated, any Entity that becomes unavailable is not identified.
In addition to no notification, I don’t see anything in the logs. Log entry for unavailable entities does say ‘changed to unavailable’.
Any suggestions?
You’ll have to provide a little more info.
Do you have the sensor set up in your lovelace config? You can see it on your dashboard? Does it work for any entity? What unavailable entity is not appearing in the sensor?
If you go to developer tools on the states tab, what do you see if you check the state for sensor.unavailable_entities?
