I have the same log
Logger: root
Source: /usr/src/homeassistant/homeassistant/bootstrap.py:307
First occurred: May 4, 2021, 9:38:12 PM (1 occurrences)
Last logged: May 4, 2021, 9:38:12 PM
Uncaught exception
RuntimeError: module compiled against API version 0xe but this version of numpy is 0xd
but I also have this log which could be related but I do not now if this is related at all
Logger: root
Source: /usr/src/homeassistant/homeassistant/bootstrap.py:310
First occurred: 8:15:00 PM (1 occurrences)
Last logged: 8:15:00 PM
Uncaught thread exception
File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.8/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 3452, in _thread_main
self.loop_forever(retry_first_connection=True)
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 1779, in loop_forever
rc = self.loop(timeout, max_packets)
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 1181, in loop
rc = self.loop_read(max_packets)
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 1572, in loop_read
rc = self._packet_read()
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 2310, in _packet_read
rc = self._packet_handle()
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 2942, in _packet_handle
return self._handle_connack()
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 3029, in _handle_connack
self.on_connect(
File "/usr/local/lib/python3.8/site-packages/ziggonext/ziggonext.py", line 220, in _on_mqtt_client_connect
client.connect(self._mqtt_broker, DEFAULT_PORT)
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 941, in connect
return self.reconnect()
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 1111, in reconnect
sock = WebsocketWrapper(sock, self._host, self._port, self._ssl,
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 3580, in __init__
self._do_handshake(extra_headers)
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 3623, in _do_handshake
byte = self._socket.recv(1)
File "/usr/local/lib/python3.8/ssl.py", line 1226, in recv
return self.read(buflen)
File "/usr/local/lib/python3.8/ssl.py", line 1101, in read
return self._sslobj.read(len)
ConnectionResetError: [Errno 104] Connection reset by peer
