Undefined reference to `vtable for esphome::my_component::my_component'
I’m trying to develop an external component because a need a custom component with actions and triggers.
I started very simple but I immediately get an error message:
undefined reference to `vtable for esphome::my_component::my_component’
This is my source
test.yaml
esphome:
  friendly_name: external component test
esp32:
  board: mhetesp32minikit
  framework:
    type: arduino
external_components:
  - source:
      type: local
      path: my_components
    components: [ my_component ]
wifi:
    ssid: !secret wifi_ssid
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
my_component:
  tx_pin: 13
__init__.py
import esphome.codegen as cg
import esphome.config_validation as cv
from esphome import pins
from esphome.const import (
  CONF_ID,
  CONF_TX_PIN,
my_component_ns = cg.esphome_ns.namespace('my_component')
MyComponent = my_component_ns.class_('my_component', cg.Component)
CONFIG_SCHEMA = cv.Schema({
  cv.GenerateID(): cv.declare_id(MyComponent),
  cv.Required(CONF_TX_PIN): pins.gpio_input_pin_schema,
}).extend(cv.COMPONENT_SCHEMA)
async def to_code(config):
  var = cg.new_Pvariable(config[CONF_ID])
  await cg.register_component(var, config)
my_component.h
#pragma once
#include "esphome/core/component.h"
#include "esphome/core/hal.h"
#include "esphome/core/log.h"
namespace esphome {
namespace my_component {
class my_component : public Component {
  public:
    void set_pin_tx(GPIOPin *pin) { pin_tx = pin; }
    void setup() override;
    void loop() override;
  protected:
    GPIOPin *pin_tx;
    void transmitCommand(int cmd);
} // namespace my_component
} // namespace esphome
my_component.cpp
#include <my_component.h>
namespace esphome {
void my_component::transmitCommand(int CMD) {
  ESP_LOGD("my_component","Command: %d", CMD);
I’m not seeing it (as newbie).
What is wrong here?
So I forget to strip setup() and loop() from my code.
Removing setup and loop fixed the error.
