sebk-666
(Sebastian)
February 13, 2017, 8:30am
1
I’m using a template sensor to monitor a (hardware) sensor’s battery state:
platform: template
sensors:
bat_fgms:
value_template: '{% if states.binary_sensor.fibaro_system_fgms001_motion_sensor_sensor_17_0 %}
{{ states.binary_sensor.fibaro_system_fgms001_motion_sensor_sensor_17_0.attributes.battery_level | int }}
{% else %}
n/a
{% endif %}'
friendly_name: 'Fibaro Motion Sensor'
unit_of_measurement: '%'
entity_id: binary_sensor.fibaro_system_fgms001_motion_sensor_sensor_17_0
Despite checking if the state object exists, I still receive this error at HA startup:
[homeassistant.components.sensor.template] Could not render template Fibaro Motion Sensor:
UndefinedError: 'mappingproxy object' has no attribute 'battery_level
How can I fix this?
Sebastian
I have a similar issue that just started on my ipad and ipad mini but works fine on my iphone. I have the same config on all 3. If I test templates in the Developer tools and put the iphone template in it works but when I change the devicetracker name to my ipad it gets the error,
here is my sensor config:
sensors:
battery_iphone:
value_template: >-
{%- if states.device_tracker.tylers_iphone.attributes.battery %}
{{ states.device_tracker.tylers_iphone.attributes.battery|round }}
{% else %}
{{ states.sensor.battery_iphone.state }}
{%- endif %}
icon_template: '{%- if is_state("sensor.battery_iphone", "unknown") %}mdi:battery-unknown{%- elif is_state_attr("device_tracker.tylers_iphone", "battery_status", "Charging") %}mdi:battery-charging{%- elif states.device_tracker.tylers_iphone.attributes.battery <= 5 %}mdi:battery-outline{%- elif states.device_tracker.tylers_iphone.attributes.battery >= 95 %}mdi:battery{% else %}mdi:battery-{{(states.device_tracker.tylers_iphone.attributes.battery|float / 10)|round*10}}{%- endif %}'
sensors:
battery_ipad:
value_template: >-
{%- if states.device_tracker.tylers_ipad.attributes.battery %}
{{ states.device_tracker.tylers_ipad.attributes.battery|round }}
{% else %}
{%- endif %}
icon_template: '{%- if is_state("sensor.battery_iphone", "unknown") %}mdi:battery-unknown{%- elif is_state_attr("device_tracker.tylers_ipad", "battery_status", "Charging") %}mdi:battery-charging{%- elif states.device_tracker.tylers_ipad.attributes.battery <= 5 %}mdi:battery-outline{%- elif states.device_tracker.tylers_ipad.attributes.battery >= 95 %}mdi:battery{% else %}mdi:battery-{{(states.device_tracker.tylers_ipad.attributes.battery|float / 10)|round*10}}{%- endif %}'
sensors:
battery_ipad_mini:
value_template: >-
{%- if states.device_tracker.tylers_ipad_mini.attributes.battery %}
{{ states.device_tracker.tylers_ipad_mini.attributes.battery|round }}
{% else %}
{%- endif %}
icon_template: '{%- if is_state("sensor.battery_iphone", "unknown") %}mdi:battery-unknown{%- elif is_state_attr("device_tracker.tylers_ipad_mini", "battery_status", "Charging") %}mdi:battery-charging{%- elif states.device_tracker.tylers_ipad_mini.attributes.battery <= 5 %}mdi:battery-outline{%- elif states.device_tracker.tylers_ipad_mini.attributes.battery >= 95 %}mdi:battery{% else %}mdi:battery-{{(states.device_tracker.tylers_ipad_mini.attributes.battery|float / 10)|round*10}}{%- endif %}'
and here are the errors:
[homeassistant.components.sensor.template] Could not render icon template battery_ipad: UndefinedError: ‘mappingproxy object’ has no attribute ‘battery’
[homeassistant.components.sensor.template] Could not render icon template battery_ipad_mini: UndefinedError: ‘mappingproxy object’ has no attribute ‘battery’
Siquel
September 27, 2018, 9:16am
4
Let me ask here too.
@sebk-666 @Tyler_Terzigni Did you guys found the solution to this problem?
I have similar errors in logs from other smart device and I have no idea how to solve it.
sebk-666
(Sebastian)
September 27, 2018, 9:59am
5
I wasn’t able to get rid of those warnings - I’m just ignoring them now.
Everything works as expected as soon as all the state objects are initialized.
Sebastian
This is what I switched to…
sensors:
battery_ipad:
value_template: >-
{%- if states.sensor.tylers_ipad_battery_level.state %}
{{ states.sensor.tylers_ipad_battery_level.state|round }}
{% else %}
{{ states.sensor.tylers_ipad_battery_level.state }}
{%- endif %}
icon_template: >
{% set battery_level = states.sensor.tylers_ipad_battery_level.state|default(0)|int %}
{% set battery_round = (battery_level / 10) |int * 10 %}
{% if battery_round >= 100 %}
mdi:battery
{% elif battery_round > 0 %}
mdi:battery-{{ battery_round }}
{% else %}
mdi:battery-alert
{% endif %}
