Underfloor heating with zone control
The 4 channel sonoffs are really a nice alternative, since they are very cost effective and have native HA support. They are about 35 euro’s each, that’s almost the same price as the Ikea Askvader models, one switch costs 10 euro. You still need the valves, temp sensors and also needs 9 volt power supply. Don’t think you included that in your price.
The Ikea Askvader option has a little less build time and has less wires. (no power supply) Also, you need some soort of casing for it.
The big ‘no’ for the 4 channel sonoff option for me was the power supply with the extra build time. (I normally earn 150 euro per hour, so time is very pricly for me. In other words, if I can save one hour build time for 100 euro, thats a win for me)
I want the regulation done on HA level, I keep ending up to the conclusion; I always have my phone with me, so there is really no need for any wall device.
You do not need the 9v Power supply. I already have 230v Mains installed (how Else would you switch the valves?) And use these for the sonoff. I had the valves already installed and they were regulated via a wall mounted thermostat. In fact you don’t even need a thermostat, as the sonoff itself acts as one. The big plus: even when the HASS server is down, it works (in theory). At least with the last given temperature.
The nice thing are the ramp-up/pi/hybrid strategies. But I would not change a running system either if I were you
The difference is just that tasmota implements the thermostat in the device itself. You could theoretically connect to it via http put requests. No need for a thermostat at all…
Thank you so much for this post!. Amazing work @Lectere ! i stumbled upon your post last night and it kept me up all night excited to achieve the same. i am in the same similar hour rate and job role except wiring (Wago is my friend) and HA are one of my favorite hobbies!
Your post made me go for a shopping spree and I can’t wait to share my approach with you!
I am in the same situation with a Daikin Altherma 3 setup roof / tank / wall unit. 3 floors with 10x 5x and 2x valves. My ground floor always gets too hot (Madoka thermostat in living room) and the unit stops too soon while the rest of the house is cold! Daikin setup is stupidly located on the ground floor which does not help on pumping the water upwards either (2x extra expansion vessels). regardless of the 300L tank my water pressure is next to non existent. This is my second house with a Daikin. My previous house (2020 build) was all on one floor and it was absolutely amazing. Did not need to touch the valves at all. having a Zoneregelaar from Uponor was almost waste of money back then.
I think your post finally thought me the ultimate purpose of a controller attached to the actuators. it’s much simpler than i always used to think. thanks for that!
Here is My approach:
  • 3x 4-channel switch module from AliExpress (Link)
    It’s equipped with RF, WiFi and even physical buttons. I have similar switches for all my lights behind all of my switches for many years and they are quite stable and integrate well with HA.
  • instead of EU plugs i’m going with a conjunction box perf floor and wiring to minimize the spacing and further push down the cost as i already have the wires (blue brown yellow).
  • The 4x main wires will have an additional physical switch before the 4x channel relay on the wire to offer another level of manual override.
  • I also already had the wifi AAA battery thermostat and humidity units from the image below in each room already so this was a no brainer for me.
I will share the pictures as soon as i receive it all and hooked up.
Couple of questions
  1. i figured from your post that you are combining valves into channels instead of 18 channels. anything in between or just simply inter-connect?
  2. the 3 minute delay of the valve vs thermostats monitoring reoccurrence. how is that working for you? any tips?
  3. what do you get on power-loss? do you do anything manual?
thanks again! you rock!
  1. Yes, I’ve done combinations, 18 loops, 10 switches.
  2. Can you rephrase the question? What do you mean with reoccurrence?
  3. In case of a powerloss, the molenhoff vales just close automatically, so yea, your heatpump ain’t doing much then either…
Thanks for the complements! Adn yes, it’s really not that hard. It’s HA controlling the switches to get the 220volt on the vales.
Keep in mind that every zone should opened at least once per month.
Thanks for the tips! . It’ll take a while until i have my Chinese hardware on :joy: so eager to try it out. I was tempted to buy the valves from china aswell except power draw is times compared (3W)
Regarding the time those valves need to close and open. I have my thermostats on every 15 minute refresh so was wondering whether you almost n3ed to match the temperature check-in times of the thermostat or get it lower than 15.
I may go for a fancier one combined with presence sensors maybe.
Just a matter of time until they equip these wall panels S8E with a presence. They already have the temperature
That Tuya 4ch relay box looks nice, are you planning on flashing it with ESPHome or keep the Original FW on it?
Hi @Lectere , I read your project and it gave me many answers as we are planning something similar. Unfortunately, we are new to HA, and as for underfloor heating, I’m also a little lost. Maybe you could give me advice or explain what I need. :pray:
We have underfloor heating but with a gas boiler - Protherm. It has a Protherm MiSet central thermostat. TECHNOLINE distributor - 11 circuits. Unfortunately, we already bought the house with this, and what’s worse, we didn’t receive any documentation for the underfloor heating, so at the moment I don’t even know which circuit is which room. But that will be a different fight.
From your project and comments that I tried to understand, I found out that I need:
  • thermo-electric actuators
  • thermostats or temperature sensors
  • some ESP
  1. Did I forget something? Is there anything else needed? Of course I know that I need drawers and similar
  2. Regarding thermo-electric actuators - I read several posts about the fact that there are 2 types - ON / OFF valves and adjustable valves. Can you tell me which ones are better and possibly why?
  3. What about ESP - do I understand correctly that it is basically DIY? Does it need to be programmed then? My husband and I work in IT, so maybe we can do something, but I’m worried if our knowledge will be sufficient. In some other post I also found Z-Wave (Multi-relay controller,Mcohome) - does this type no longer need to be programmed? Or did I misunderstand something?
  4. My last question is about my central thermostat. Can I disconnect it then? How exactly or on the basis of what will my boiler know when to start heating?
Ended up getting another 10 channel for downstairs. No i use tuya integration and that works perfectly fine
Hi there,
I also working on an underfloor heating solution.
Instead of Ikea plugs I will use Shelly Plus 2PMs.
The generic thermostat entity is clear to me.
But need I (in my case) 6 entities in the config.yaml or can I create them in an additional yaml for a better overview?
I will use the generic thermostats with an automation.
Is it possible to create an automation with an input_boolean switch on and off?
if on then run gen.therm.?
which condition I need to choose for this automation?
This PWM feature looks really nice / what I was looking for!
Do you have any remarks after using it for a winter?
Would you be able to share a list of hardware you’ve combined (temp sensors / thermostat?, thermal “motors”, additional items, …)?
thanks!
Hi Lectere,
That was a very helpful write-up. I’m researching exactly a setup like yours for our house that is being newly built. I especially don’t want to have to put a thermostat in every room: a simple temperature sensor should be enough to then allow Home Assistant to act as a virtual thermostat. I also briefly looked at a Honeywell HCC100 solution, but it still requires its own thermostats as input devices.
Your solution is very close to what I would like. The only thing I’m missing in the description of your solution is how you process the signal from the heat pump when it goes into cooling or heating mode. What interface do you use for this? And what what if HA misses this signal? Can you simply read the current state of the heat pump with Home Assistant?
Lastly, I am also very curious about “lessons learned” now that you are a year along with this setup.
Thanks, my retrospect;
  • First of all, very happy with the end result!, works well. Never once did a switch fail. Never once did the heatpump didn’t go on.
  • Everything works automatically, I don’t have to do anything
  • Home assistant is, because of this, very important, again for me a basic setup; no hypervisor, no reverse proxy, HAOS on hardware with UPS.
  • The Sonoff Snzb-02d is very nice, I and my wife like the display on the device. And battery replacement doesn’t require the device to be added again.
  • I combined all the zones on the ground floor, and I almost only heat there
  • I never heat the sleeping room, only cooling
  • I need to make something that will open the valves only when they been closed for longer than a month.
  • placement of the Sonoff snzb-02d is important, once my wife place a candle under one… And my son took the one from the living room to his room…
I’ve shared the automation to start the heatpump in the original post when one of the groups goes open, and I use the outside temp to determine it’s heating or cooling, above 22 degrees means cooling…
(I use ESPAltherma)
actions:
- if:
- condition: numeric_state
entity_id: sensor.openweathermap_temperature
above: 22
then:
- device_id: heatpump
domain: select
entity_id: mode_select
type: select_option
option: Cooling
else:
domain: select
type: select_option
option: Heating
Nice post! It looks much like what we did for our own house. However, I would recommend not to rely on mechanical relays and wifi or other wireless connections to make the heating of your house comfortable. We have developed our own piece of hardware, that can also connect to (wired) 1-wire temperature sensors like the ds18b20. It contains solids state relays, and all IO is wired to make it maximal reliable.
You might also want to check out the approaches for a PID thermostat; it can prevent your heating system from overshoot, saving you more energy.
I just found this topic, and it was exactly what I was looking for. I have an existing underfloor zone controlled heating system. There are 12 loops divided over 5 zones. I really want to create an additional zone by splitting up one zone with two loops into two zones. Unfortunately, my current zone controller doesn’t support an additional zone and the propriety thermostats are wired solutions which makes it much much harder.
My current actuators are 24V, so I have been looking into Kliplinc ESP8266 WiFi 16 Channel Relay Module ESP-12F Development Board Power Supply, 16-Way Relay Module, Power Mode 24V : Amazon.nl: Business, Industry & Science. But how do I power this? I have some ESP32 / ESP8266, but they use a USB connector. And they come in 5V, 12V and 24V, i’m assuming this means to power the actuators and not for powering the board, right?
I already have ordered a new 24V actuator (and to be sure an 230V too). So hopefully you guys can help me with this, so I can finally provide my 4-year-old with a better temperature in his room.
I just ordered the following:
We’ll see if it works.
There is a screw thermal at the bottom right of the first picture, that looks like the power for the board.
Yes I have seen that, but I don’t see any adapters suggested. I have a bunch of esp modules powered by microusb, this one doesn’t have a usb connector. Does that mean I still am able to use a usb power plug but with the cables stripped or should I use an entirety different adapter.
Since the images say 24 volt DC then I assume USB is not enough
I have the same question. I understand that @Lectere is using ON/OFF valves. But since I only have underfloor heating and a lot of inertia, I would like to have the ability to have some valves partially open. I think it is more energy efficient to always have a (minor) flow of water at a lower temperature.
Does anyone have adjustable valves (PWM?)? Any experience that can be shared?
I doubt it be more energy efficient for floor heating. With a heat pump everything stands and falls with your COP. The pump/waterflow only takes account for very very little energy. Plus you also always have a bypass valve/pressure differential. So I don’t know if that’s very wise…
