Understand an error, need help
Every time that HA reboot I got this error, but I have not understood how solve it.
Any help will be really appreciate.
Invalid config
The following integrations and platforms could not be set up:
  • entity
  • type
Please check your config and [logs].
Home Assistant Core log
  • Uncaught thread exception
    12:39:32 – (ERROR) helpers/entity.py
Error doing job: Future exception was never retrieved (None)
12:39:32 – (ERROR) helpers/entity.py - message first occurred at 12:39:32 and shows up 2 times
Setup failed for ‘entity’: Integration not found.
12:36:52 – (ERROR) setup.py - message first occurred at 12:36:52 and shows up 2 times
Failed to load integration for translation: Integration ‘type’ not found.
12:36:45 – (WARNING) helpers/translation.py - message first occurred at 12:36:45 and shows up 2 times
You likely have some errors in your configuration.yaml. Please show it (format it correctly too).
You are btw exposing your HA instance URL in the links.
