Title: Understand and Use Home Assistant Statistics
Introduction
I am currently working on an integration for Home Assistant that makes extensive use of statistics. Over the past few weeks, I have been reviewing all the information I could find on this subject — official documentation, developer sources, community posts — and conducting numerous experiments to better understand how statistics actually work under the hood.
I usually record information as I collect it, so I have created a comprehensive set of documents that I think might be of interest to others in the community. Whether you are trying to understand why your energy dashboard shows wrong values, need to change a sensor’s unit of measurement, or want to explore your database with SQL — this documentation should help.
Where to find the documentation
I have created a GitHub repository with all the documents. You can read them:
As a website (recommended): Understand and Use Home Assistant Statistics
As Markdown on GitHub: GitHub - DrCoolzic/ha-statistics-doc · GitHub
What’s covered
The documentation is organized into five main parts plus appendices and SQL examples:
Part 1 — Foundational Concepts: How HA Core works as an event-driven system, entities, states, the Recorder integration, and the
statestable structure -
Part 2 — Statistics Generation: How raw state data is transformed into short-term (5-minute) and long-term (1-hour) statistics, measurement vs counter types, mean calculations, sum accumulation, and the database schema
Part 3 — Working with Statistics: How to access statistics through the UI (Developer Tools, Energy Dashboard, History/Statistics graph cards), via services, and through direct SQL queries
Part 4 — Best Practices & Troubleshooting: Choosing the right
state_class, recorder configuration, common pitfalls, and a troubleshooting decision tree -
Part 5 — Find & Fix Statistics Errors: Detecting and repairing data gaps, spikes, orphaned entries, renamed entities, counter reset failures, wrong mean types, and more — with SQL queries and step-by-step fix instructions
Additional documents available on the repository:
Appendix 1 — Deep dive into the mysterious
created_tsandmean_weightfields -
Appendix 2 — Examples of statistics from non-sensor domains (number, input_number, counter)
Appendix 3 — How HA selects, stores, and displays units of measurement
Appendix 4 — Step-by-step guide to changing units on sensors with existing statistics
SQL Examples — Ready-to-use queries for states, statistics, and error detection
For now, ignore appendices 3 and 4 concerning units of measurement. I thought I had finalized them, but every time I run tests on the subject, they contradict my conclusions. This is particularly true for changing units on sensors…
Important notes
This documentation is based on Home Assistant documents and thorough testing, so it should be relatively accurate. However, it will inevitably contain errors or omissions — HA evolves quickly and some behaviors are not well documented.
I will try, depending on the time I have available, to answer questions and correct errors.
Contributions, corrections, and suggestions are welcome — feel free to open an issue or pull request on GitHub.
Enjoy! ![]()
