Hi, it has been a few days that I have started with writing AppDaemon apps and there are a few areas on which am a little confused and that is why not able to take some design decisions for the automations. This confusion mostly revolves around timers and listeners.
I have an app which has
run_everyorrun_attimers setup in the callback methods oflisten_state, note that it is not in the initialize method-
Now, is this design acceptable or I should avoid using such design techniques?
- The idea here is that I want to start a
run_everyonly when one of the sensors reaches a state ofon.
Consider that a timer is already running after the sensor triggered the
run_everyscheduler, what happens if HA restarts or AD restarts? Will the timer pick up from where it left off or the timer will be canceled because AD reinitialized the app after a restart?- Reasons could be many, one of them may be a power failure
Another scenario, I am listening to the door state of open and in the callback, starting a timer,
run_everyjust like the above point and then going ahead and canceling the timer when the door state is off. Now here what will happen if I quickly opened and closed the door lets say 5 times. Will the previous instances get terminated or its gonna be a chain of events lined up and waiting for execution?
There are few more scenarios which I want to highlight but will do it ones there is an explanation to the above points, I want to rethink them based on suggestions and see if they are even valid now or not.
Any pointers will be really appreciated.
