Understanding Bluetooth and BLE and ESP32 BLE Proxies?
Background: I have both SmartThings, and HomeAssistant running 200+ devices, and a bunch of integrations including OmniPool, Honeywell, Airthings, etc. Mostly Zwave but a few Zigbee in the mix as well. HA is running on a Raspberry Pi 4 for now.
When and why would I need a BLE proxy running on ESP32?
I do have a BLE pressure sensor that I’d like to connect up but it’s outdoors and I think outside the range of where my HA sits. I also have an presence tag I’m playing with to tell if the trash can is at the street or in the garage as well.
My understanding is I would need an ESP BLE Proxy to be near where those sensors are to pick up their telemetry?
Yes, this is a usecase where bluetooth proxies would work.
Thanks @fleskefjes. As I understand it then, I configure BLE PRoxy on ESPs along with wifi (or maybe a POE hat), but then do I need to define the sensors on the ESP as well or will the BLE devcies handle that?
The proxy is defined in the esp device.
Once that’s done - think of it like nothing more than another Bluetooth endpoint near wherever. Then other integrations (like one called Bermuda) can just use it without needing to care if it’s a proxy or a direct attached Bluetooth radio.
Thanks @NathanCu. So if I have multiple BLE Proxies throughout my location, how would I tell and or report on which devices are connected to which proxies?
From some reading is sounds like I could actually use this type setup to detect presence of things… but mostly I’m just curious if I can see that device X is connected to Proxy Y
The other integrations do that. Like I said the proxy is just the antenna.
For instance Bermuda which I mentioned once installed it automatically uses the proxies you tell it to use and when it ‘sees’ a device it marks a specific entity with the area of the closest proxy… (not perfect but the best available right now a d it’s being updated regularly…)
So basically install proxy, then do not worry much more about them except - still working? Then, find integrations that say 'works with Bluetooth proxy (which at this point is most of them if they do Bluetooth or BLE)
Thanks… so in theory… I have an ESP32 with 4 relays that I’ve already built for my pool equipment. Wifi connected. Inputs are a hardwired pressure sensor, and outputs are a couple of relays used to control some landscape lighting. I’ve also installed OTA, webserver, etc.
I also have a BLE pressure transducer on the filter. Now I’m thinking I could use the BLE proxy to read that? presently I can only read it with a phone app (as long as I’m near it). The vendor makes a Bluetooth router that I think I might be able to avoid having to purchase… (and learn along the way)
If there is an integration that reads it via Bluetooth then chances are of you setup those esp32 to add Bluetooth proxy then it most likely will.
To chime on on what Nathan said - I use the proxies for the MiFlora plant sensors (from Xiaomi). They get auto-discovered by HA like this:
This is the most important part. If there is (and you have it installed, in the case of a custom integration), it will generally be auto-discovered. If not, then you’re out of luck unless you’re capable of making an integration for it.
