Hi
Just new at HA and installed it yesterday running a VM with VMware Photon OS and docker on it, then installed following the install on Docker guide. I managed to add my Tuya lights and control them. Now while playing with scenes I get some strange results and found an instruction on how the make some changes to the configuration.yaml file to have better control ( https://www.home-assistant.io/integrations/scene/ ).
But the configuration.yaml file is next to empty. Why can’t I see the scene I’ve been testing in the configuration.yaml file? Is this configuration part stored in the database? If so, how can I edit that?
I can’t figure out how the database and the configuration.yaml file play together. How can I easily see a logging of how the configuration.yaml file is read and if all is accepted what is in the file?
Oh… duh… sorry I didn’t see the scenes.yaml. Yes it is there and has the entries.
So just to be sure. The database stores much of the historical data and some configuration settings, but most things to into files like scenes.yaml, scripts.yaml, etc and these files should get updated then.
