Hi All,
So i’m working on an automation, simple, check if its hotter outside than inside, if it is, send me a message a few times and then no more. I saw that there is a ‘delay node’ where I could set a “rate limit” to only send something like 10msg’s per 1 day.
When I try this, everything executes one time, and after that, it stops running. even my “events: state node” stops updating after one message. I have to re-deploy in order for it to work again. I currently have it set to 10 messages per day but at most I can only get 1 before the whole automation just kinda dies. Maybe im misunderstanding?
Logic: Office temperature hotter than backyard temp, is it between 5pm and 11:59PM, limit messages to only 10 per 1 day, check to make sure I’m home, send me a message.
"id": "204f7f3cdd61d953",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": ""
"id": "7d4e29941beb6835",
"type": "server-state-changed",
"z": "204f7f3cdd61d953",
"name": "Backyard Temperature",
"server": "70ffd67b.7b6ef8",
"version": 3,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.acurite_tower_a_6432_t_side",
"entityidfiltertype": "exact",
"outputinitially": false,
"state_type": "num",
"haltifstate": " $number($entities(\"sensor.office_temperature_2\").state) > $number($entities(\"sensor.acurite_tower_a_6432_t_side\").state)",
"halt_if_type": "jsonata",
"halt_if_compare": "jsonata",
"outputs": 2,
"output_only_on_state_change": false,
"for": "1",
"forType": "num",
"forUnits": "seconds",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 160,
"y": 300,
"wires": [
"5de61fe7b305601c"
"id": "7bd52af737c555f6",
"type": "api-call-service",
"name": "Message Jon",
"version": 3,
"debugenabled": false,
"service_domain": "notify",
"service": "mobile_app_lephono13dejon",
"entityId": "",
"data": "{\"message\":\"It's currently {{payload}}F in the backyard.\",\"title\":\"Open the Office Window\"}",
"dataType": "json",
"mergecontext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 870,
"y": 300,
"wires": [
"id": "acc5a6bbc68b4114",
"type": "api-current-state",
"name": "Jon's Home",
"version": 2,
"outputs": 2,
"halt_if": "home",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "device_tracker.lephono13dejon",
"state_type": "str",
"blockInputOverrides": false,
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 710,
"y": 300,
"wires": [
"7bd52af737c555f6"
"id": "5de61fe7b305601c",
"type": "time-range-switch",
"name": "",
"lat": "",
"lon": "",
"startTime": "17:00",
"endTime": "23:59",
"startOffset": 0,
"endOffset": 0,
"x": 360,
"y": 300,
"wires": [
"5c56fe969000a39e"
"id": "5c56fe969000a39e",
"type": "delay",
"name": "",
"pauseType": "rate",
"timeout": "5",
"timeoutUnits": "seconds",
"rate": "10",
"nbRateUnits": "1",
"rateUnits": "day",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": true,
"allowrate": true,
"x": 540,
"y": 300,
"wires": [
"acc5a6bbc68b4114"
"id": "70ffd67b.7b6ef8",
"type": "server",
"name": "Home Assistant",
"version": 1,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true
I appreciate the help
Jon
