I´m fairly new to Hass, and appreciate some help understanding the different identity listings…
The four entries shown below is for my Heiman Technology Co. Ltd Smart Smoke Sensor HS1SA-Z smoke detector (link).
What is the difference between the four entries my the entities list?
bottom one is the zwave node properties. Top 3 are sensors that are created from the zwave node. It’s up to you to figure out what the 3 sensors are. The sourcenodeid is typically useless, so you can safely ignore it. The other 2 may or may not be important. Trigger the device and watch the states to figure out what they are.
The binary sensor turns on when smoke is detected and when I press the test button on the alarm - but the values of the other sensors don’t seem to change so I can’t distinguish between a test and smoke being detected.
I have a “Mute Sirens” input boolean. If it is set a condition in my smoke alarms automation only turns on my alarm strobe lights without setting off the sirens, sending alerts and turning all the house lights on.
I have another automation that turns off the siren mute input boolean after 3 minutes - thus hopefully preventing failed alarms if the Testing mode is left on.
## Smoke Alarm Automation
- id: smoke_alarm_triggered
alias: 'Smoke Alarm Triggered'
initial_state: true
platform: state
entity_id:
- binary_sensor.smoke_hall
- binary_sensor.smoke_lounge
- binary_sensor.smoke_rumpus
- binary_sensor.smoke_comms
to: 'on'
- service: switch.turn_on
entity_id:
- switch.strobe_upstrs
- switch.strobe_dnstrs
- condition: state # Only if test mode is off CAUTION!!!
entity_id: input_boolean.mute_sirens
state: 'off'
entity_id:
- switch.siren_upstrs
- switch.siren_dnstrs
