as said before, I came here from OpenHAB and I am very happy with my choice to switch. What took me weeks in OpenHAB is done in HA in an afternoon, everything is very straight forward.
However I am very confused on the groups implementation.
In OpenHAB, when I create a group of lights, thermostats etc, I can do what I would expect: send a temperature to the thermostats group and all thermostats in the group get set to that temperature.
Same for lights, covers, etc. This is extremely important to create automations without listing each single device and having to change that X times when I get a new device or move one… (so essentially all the reasons why you use groups anywhere in IT).
But when I created a group of thermostats in HA, it was not available to the thermostat card as it was not belonging to the climate domain. I also found no wy to put it in the climate domain.
Instead I found a script from somebody here in the community that does exactly that. However it is only working partial, changing the thermeostats mode fails.
Now my question: Is the group concept in HA really imited like this? Or am I missing something? Or is it just not finished yet and I only need to be patient? In consider this as a very basic and important feature.
Are you sure that will work? That will add brackets into the string. I would assume that this is what would be needed. I haven’t tested, just curious (as I don’t use automations).
Without join it returns ["group.whatever"] which is what the second YAML format produces. EXCEPT you’ve reminded me that Jinja2 will deliver it as a string so that’s not good.
In contrast, with join the output appears to be identical to the first YAML format which reportedly doesn’t work in this particular application.
I’ve noticed that some entity_id fields in data templates don’t accept the 'item, item' notation. I think it would be advantageous to find out all the fields that don’t allow it and make an issue to get it corrected.
FWIW, the difference is in treating the group as a single entity:
entity_id: group.whatever
versus treating is as a single element of an array:
entity_id:
- group.whatever
While they should both operate the same from an execution standpoint, because you’re sending commands and want to operate on each element of the group, I can see why the second works (hey here’s a group of elements in an array) and the first doesn’t (hey here’s a single element).
At least I now know that I can set the temperature of a group of thermostats in an automation, better than nothing.
However I really think that it should be possible to create a group of any type and then send collective commands to all members as if it was a single item.
That’s yaml and it depends on the validation on the element. entity_id accepts lists or a single item. Some services allow entity_id to contain 1 element that is a comma separated list (Like light.turn_on). Apparently, climate.set_temperature does not allow this.
