I have an automation which enable my airconditioning on several triggers.
As an action I have Choose and 5 options.
But will every pad be followed when all conditions are true or only the first option that have all conditions true?
I want to know for example. The temperature in all area’s is 25° but there is not enough solar production than the automation will not run.
But later on the day the automation will be triggered because there is enough solar production. Will only the first option run or will all options run that have all conditions to true?
This is my automation:
alias: Airco inschakelen per kamer
description: Airco inschakelen bij bereiken ingestelde temperatuur
triggers:
- entity_id:
- sensor.tvoc_living_temperature_sensor
above: 24
id: Living te warm
trigger: numeric_state
- entity_id:
- sensor.tvoc_slaapkamer_temperature_sensor
above: 24
id: Slaapkamer te warm
- trigger: numeric_state
entity_id:
- sensor.temperatuur_logeerkamer
above: 24
id: Logeerkamer te warm
- entity_id:
- sensor.temperatuur_zolder
above: 24
id: Zolder te warm
enabled: true
- entity_id:
- input_boolean.slapen
to: "off"
trigger: state
- trigger: state
entity_id:
to: "on"
entity_id:
- sensor.smartmeter_huidige_teruglevering
for:
hours: 0
minutes: 5
seconds: 0
above: 1500
id: Voldoende teruglevering
entity_id:
for:
hours: 0
minutes: 5
seconds: 0
below: 1
id: Onvoldoende teruglevering
conditions:
- condition: state
entity_id: input_boolean.airco_modus
state: "on"
actions:
- choose:
- conditions:
- condition: trigger
id:
- Opstaan
- Living te warm
- Voldoende teruglevering
- condition: numeric_state
entity_id: sensor.tvoc_living_temperature_sensor
above: 24
- condition: state
entity_id: input_boolean.slapen
state: "off"
entity_id: sensor.smartmeter_huidige_teruglevering
above: 1500
sequence:
- data:
hvac_mode: cool
temperature: 22
entity_id:
- climate.living_room_temperature
action: climate.set_temperature
alias: Airco living aanzetten
- conditions:
id:
- Opstaan
- Slaapkamer te warm
entity_id: sensor.tvoc_slaapkamer_temperature_sensor
above: 24
- condition: state
state: "off"
above: 1500
sequence:
- data:
hvac_mode: cool
temperature: 20
entity_id:
- climate.slaapkamer_room_temperature
alias: Airco slaapkamer aanzetten
- conditions:
id:
- Opstaan
- Logeerkamer te warm
entity_id: sensor.temperatuur_logeerkamer
above: 24
- condition: state
state: "off"
above: 1500
sequence:
- data:
hvac_mode: cool
temperature: 20
entity_id:
- climate.logeerkamer_room_temperature
alias: Airco logeerkamer aanzetten
- conditions:
id:
- Opstaan
- Zolder te warm
entity_id: sensor.temperatuur_zolder
above: 24
- condition: state
state: "off"
above: 1500
sequence:
- data:
hvac_mode: cool
temperature: 18
entity_id:
- climate.zolder_room_temperature
alias: Airco zolder aanzetten
- conditions:
id:
- Slapen
- Onvoldoende teruglevering
sequence:
- action: script.alle_aircos_uit
metadata: {}
data: {}
mode: queued
max: 10
