Hey Guys, I’m the new Kid in town, I just started to play around with HA.
I have used other home automatino before, like OpenHAB and iobroker but I never liked that Java stuff because it is always a ressource killer. Not that I don’t have enough CPU Power and RAM available but it still is all kind of slow responding.
I really like that about HA. A friend of mine pointed me here and also is starting from scratch at the moment.
I took the slightly harder aproach and not just setup a RaspberryPi, I have Home-Assistant running inside an LXC container hosted by Proxymox and run HA on plain Debian Stretch.
The documentation is a bit of an issue to me. There are often code snipits but sometimes it seems they are not very complete, so it’s hard to learn. I would say about myself I’m not a Linux professional but also not a total noob. So I think I can read and follow documentation and guides.
Never the less, the installation was kind of straight forward. I think I still miss some debian packages, but also figured out to install some, already.
It took me a while to understand that I don’t have the components “shop” available (becasue I did not install haasio) but it seems all components are just there and I can just use them. So it would be really nice to have a getting started guide for intermediate users like me, even though the PI-way probably is the easier one but I have Proxmox Running anyway, so it doesn’t really make sense for me, similar to the usage of Docker.
Please don’t get me wrong, this is my first post here and I do a lot of complaing, but I see this as good way to contribute to such a project. Especially because I have no experience with HA so far and I’m probably not the only person haveing such (minor) problems getting started.
What I really like is the possibility to do all configuration in config files becasue you can just share them. So I wanted to start making use of the secret.yaml. But I don’t understand how to set it up, even the documentation gives a small example.
So I want to combine this: https://www.home-assistant.io/docs/configuration/secrets/
With this: https://www.home-assistant.io/components/homematic/
The homematic section of my config.yaml looks like this.
I want to move the IPs and the Usernames and Password to the secret.yaml
# Homematic
homematic:
interfaces:
rf:
host: 192.168.xxx.xxx
resolvenames: json
username: Admin
password: Sup3r-P4ssw0rd
groups:
port: 9292
resolvenames: json
username: Admin
path: /groups
hosts:
ccu2:
username: Admin
So I would probably change the config.yaml to
# Homematic
homematic:
interfaces:
rf:
host: !secret homematic_host
resolvenames: json
username: !secret homematic_username
password: !secret homematic_password
groups:
port: 9292
resolvenames: json
path: /groups
hosts:
ccu2:
But how do I need to setup the secret.yaml accodingly? Just like so:?
homematic_host: 192.168.xxx.xxx
homematic_username: Admin
homematic_password: Sup3r-P4ssw0rd
EDIT: And do I need to include the secrets like the other files?
group: !include groups.yaml
script: !include scripts.yaml
