I am trying to make a custom test platform, and trying to understand what is going on by diving into the code, I have read the minimal docs for creating a platform at dev.home-assistant.io and am currently stuck
I am using this code:
import logging
import voluptuous as vol
from homeassistant.components.switch import SwitchDevice
from random import randint
_LOGGER = logging.getLogger(__name__)
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Setup the software light"""
ports = config.get('lights')
_LOGGER.debug("port list: %s type %s", ports, type(ports))
lights = []
for light_num, light_name in ports.items():
_LOGGER.debug("ports.items num: %s name: %s type: %s", light_num, light_name, type(light_name))
lights.append(SoftwareSwitch(light_name))
_LOGGER.debug("list of lights %s", lights)
add_entities(lights, True)
class SoftwareSwitch(SwitchDevice):
"""Software Light"""
def __init__(self, name):
_LOGGER.debug("initialized %s", name)
_LOGGER.debug("initialized type %s", type(name))
self._name = name
self._state = True
def name(self):
return self._name
def should_poll(self):
return True
def is_on(self):
return self._state
def turn_on(self):
self._state = True
self.schedule_update_ha_state()
def turn_off(self):
self._state = False
def update(self):
if (randint(0,5) == 1):
self._state = not self._state
_LOGGER.debug("updating Software Light name: %s %s", self._name, self._state)
And this code inside my configuration file:
switch:
- platform: software_switch
lights:
0: light one
1: light two
I have tried writing it as a light component as well, and have been referencing the various platforms inside switch and light (Yeelight, gpio_sensor, (in binary_sensor), demo.py, abode.py eufy.py etc)
I am getting this error:
2018-09-13 21:47:18 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 332, in _async_add_entity
self.domain, suggested_object_id)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_registry.py", line 108, in async_generate_entity_id
'{}.{}'.format(domain, slugify(suggested_object_id)),
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/__init__.py", line 46, in slugify
text = normalize('NFKD', text)
TypeError: normalize() argument 2 must be str, not method
I can modify line 322/323 (of homeassistant/helpers/entity_platform.py
) from
suggested_object_id =
suggested_object_id or entity.name or DEVICE_DEFAULT_NAME
to just suggested_object_id = "no_name"
Then it creates a different error on line 191-193 in homeassistant/helpers/entity_component.py
in the lambda function that it cannot sort (method() >method()
I have tried my best to find out what is wrong, but cannot seem to figure it out spent the last few hours dealing with this don’t know what to do to solve it.
Thanks!
Also homeassistant version is 0.77.3
