Unexpected error during intent recognition
Hey everyone
I’m not sure if this is the right place for it but I decided to finally set up assist recently (a few days ago) and when I did, everything was working perfectly - I was even able to make custom intents and sentences and they worked well.
However, all of a sudden when I went to try again today (first time since setting it up), no matter what I say/type, i just get this error (see picture below):
Unexpected error during intent recognition (intent-failed)
This is a screenshot of the assistant debug screen, and the raw error message from the error (I’ve removed the pipeline id just in case it’s needed since I’m not sure, but there is a pipeline id normally)
stage: error
run:
  pipeline:
  language: en
  runner_data:
    stt_binary_handler_id: null
    timeout: 30
events:
  - type: run-start
      pipeline:
      language: en
      runner_data:
        timeout: 30
    timestamp: "2023-05-25T00:10:40.959224+00:00"
  - type: intent-start
      engine: homeassistant
      language: en
      intent_input: turn on kitchen light
    timestamp: "2023-05-25T00:10:40.959268+00:00"
  - type: error
      code: intent-failed
      message: Unexpected error during intent recognition
    timestamp: "2023-05-25T00:10:40.970928+00:00"
intent:
  language: en
  done: false
error:
  code: intent-failed
I don’t know what’s changed or how to fix it, but I can’t even use default assist intents like turning on a light. I’m still quite new to HA and haven’t had to troubleshoot anything like this before so I don’t quite know where the logs for this sits or how to access them, but if someone could point me in the right direction I can add the logs to here as well.
I’ve also restarted HA and tried on multiple browsers/devices and it’s all the same - no matter what I type (whether it’s an actual sentence/intent or not), it just immediately comes back with that error.
If anyone knows how I can fix it or debug more, that would be appreciated! Thanks in advanced!
I also have a similar error here but not resolved :frowning:
I ended up finding the answer! Someone on discord pointed out that when I was making custom intents, I had some files in use that were blank. It errored because it tried to read it but it was empty. They looked at the code and saw a way to fix it and have put it through as a pr hopefully
Here’s the git of it HA assist erroring when you have empty custom sentence files · Issue #93528 · home-assistant/core · GitHub
Not sure if it’s the same issue as what you’ve got, but it’s worth a shot!
This was it! I had an empty sentence field in my automation. When deleting it the problem was gone.
For those bumping into the same error, it’s worth noticing that an error in your (automation trigger) sentence can also cause this error. This error is not noticed when saving your automation.
Reported as a HA core bug here: AssertionError: Text is too short when an autmation has an empty sentence trigger · Issue #103540 · home-assistant/core · GitHub
This was the case when I had drafted a new automation with some empty parts still in it. Also disabling did not solve it but deleting did
Thank you so much! This fixed it form me. I had an empty “custom_sentences” folder with nothing in it.This generated the error for me as well. I deleted the entire folder and after that, it worked! I used the latest Mistral-Small 3.2 locally. I go so crazy about this folder. what a strange behavior.
Im still having this issue and dont have a custom_sentences folder
I don’t have a custom_sentences folder either.
same no custom_sentences, something strange is happening though, second time this has hapepened on 2026.1 and 2026.1.1 but random, nothing has changed and it just stopped on 14 Jan
I found the issue for me, I created conversation automations and in one of the sentences I used { instead of ( . Once I replaced that, the commands were held in a queue and lights started turning on and off from all my tests LOL
