Unexpected error fetching environment_canada radar data
what is the missing arguments?
Log details (ERROR)
Logger: homeassistant.components.environment_canada.coordinator
Source: helpers/update_coordinator.py:354
integration: Environment Canada (documentation, issues)
First occurred: 6:18:50 PM (1 occurrences)
Last logged: 6:18:50 PM
  File "/usr/local/lib/python3.12/site-packages/aiohttp/resolver.py", line 104, in resolve
    resp = await self._resolver.getaddrinfo(
aiodns.error.DNSError: (1, 'DNS server returned answer with no data')
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1301, in _create_direct_connection
    hosts = await self._resolve_host(host, port, traces=traces)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 911, in _resolve_host
    return await asyncio.shield(resolved_host_task)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 948, in _resolve_host_with_throttle
    addrs = await self._resolver.resolve(host, port, family=self._family)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/resolver.py", line 113, in resolve
    raise OSError(msg) from exc
OSError: DNS server returned answer with no data
  File "/usr/local/lib/python3.12/site-packages/env_canada/ec_radar.py", line 194, in _get_basemap
    base_bytes = await _get_resource(map_url, basemap_params)
  File "/usr/local/lib/python3.12/site-packages/env_canada/ec_radar.py", line 109, in _get_resource
    response = await session.get(
  File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 657, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 564, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 975, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1307, in _create_direct_connection
    raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host maps.geogratis.gc.ca:443 ssl:default [None]
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 354, in _async_refresh
    self.data = await self._async_update_data()
  File "/usr/src/homeassistant/homeassistant/components/environment_canada/coordinator.py", line 29, in _async_update_data
    await self.ec_data.update()
  File "/usr/local/lib/python3.12/site-packages/env_canada/ec_radar.py", line 337, in update
    self.image = await self.get_loop()
  File "/usr/local/lib/python3.12/site-packages/env_canada/ec_radar.py", line 359, in get_loop
    await self._get_basemap()
  File "/usr/local/lib/python3.12/site-packages/env_canada/ec_radar.py", line 198, in _get_basemap
    logging.warning("Map from %s could not be retrieved: %s" % map_url, e)
TypeError: not enough arguments for format string
template:
  - trigger:
      - platform: time_pattern
        hours: /1
      - platform: homeassistant
        event: start
      - service: weather.get_forecasts
          type: hourly
          entity_id:
            - weather.peterborough_forecast
            - weather.home
        response_variable: hourly
      - name: Today Rain
        unique_id: today_rain
        state: "{{ (hourly['weather.home'].forecast[0].precipitation | default('nan')) }}"
        #state: "{{ forecast['weather.home'].forecast[0].precipitation }}"
        availability: "{{ is_number(hourly['weather.home'].forecast[0].precipitation ) }}"
        unit_of_measurement: mm
      - name: Temperature forecast next hour
        unique_id: temperature_forecast_next_hour
        state: "{{ hourly(['weather.peterborough_forecast'].forecast[0].temperature | default('nan'))}}"
        #state: "{{ forecast['weather.peterborough_forecast'].forecast[0].temperature }}"
        availability: "{{ is_number(hourly['weather.peterborough_forecast'].forecast[0].temperature) }}"
        unit_of_measurement: °C
and i have some dict errors with the state and avaliability… it doesnt like it i guess if it cant connect to interent it gives me error i guess??
i keep trying to fix the weather errors but the one that keeps coming up is the
Error rendering availability template for sensor.today_rain: AttributeError: 'float' object has no attribute 'lower'
Error rendering availability template for sensor.temperature_forecast_next_hour: AttributeError: 'float' object has no attribute 'lower'
i keep changing and adding but how you fix it it?
template:
  - trigger:
        hours: /1
        event: start
          type: hourly
          entity_id:
            - weather.home
      - name: Today Rain
        state: "{{ hourly['weather.home'].forecast[0].precipitation |float(0)}}"
        availability: "{{ has_value(hourly['weather.home'].forecast[0].precipitation) }}"
        state: "{{ hourly['weather.peterborough_forecast'].forecast[0].temperature | float(0)}}"
        availability: "{{ has_value(hourly['weather.peterborough_forecast'].forecast[0].temperature) }}"
