Thank you @ReneTode
Restarting again Hassio Appdaemon seem to starts without errors…
From some days I suffer from many errors in HA
It start very slowly (about 4 minutes)
sometimes it show me errors like…
[homeassistant.components.recorder] Ended unfinished session
[homeassistant.setup] Setup of hassio is taking over 10 seconds.
[homeassistant.components.hassio.handler] Timeout on /supervisor/options request
not all automations are started… becouse some automations works and some other do not works.
you got hassio, probably on an RPI?
and you got recorder and history on.
that gives a heavy load on the SD card.
and SD cards go bad over time when you do a lot of writing to it.
so its very well possible that your SD card is going bad.
when HA takes long to startup, you need to make sure that apps are written well and that they check if all needed components in HA are already started.
Yes I have Hassio installed on Rpi3
I use recorder function
I can try to disable the recorder function but it was useful when something was not working or working badly
I replaced SD card less than a month ago with a new Samsung EVO Plus 32 GB, UHS-I 95 mb / sec
If I decide to use a better hardware for Hassio what do you suggest me?
I saw many people installed it on a mini pc with Ubuntu Server 16.4
If I will buy a mini PC …with Intel N3450 and I install Ubuntu it will be more performant?
i also moved to a mini pc (a beebox) over a year ago. and indeed i also installed ubuntu (18 at the moment)
i think i got my beebox restarted 3 times in the last year.
with 4x AD, 2x HA, mosquito and nginx running i got up to 15% cpu, still lots of space (with 4 cams connected to FTP server on the beebox) but i bought a 240 Gb SSD
even with 4 GB ram i got plenty.
thats absolutely not a bad investment, and i am sure this will hold for years.
so it did show excessive time with external url, but not without?
in that case your internet connection was slowing things down.
AD has a timeloop from 1 second. if actions take up longer then that it leads to those warnings.
when its rare and not high, you dont need to worry about it.
nope isnt strange.
its not how fast your connection is.
but all connections between your router and your DNS server.
including the DNS server itself.
so if only 1 off those connectionpoints or the DNS server is more busy as usual, then the connection from your AD to your HA will get a holdup.
thats why you dont want AD to connect to HA through outside DNS
2019-01-17 09:14:52.260314 INFO alarm_system: Stopping camera snapshot timer
2019-01-17 09:14:52.283436 INFO alarm_system: Starting camera snapshot timer
2019-01-17 09:14:53.019855 WARNING AppDaemon: ------------------------------------------------------------
2019-01-17 09:14:53.020961 WARNING AppDaemon: Unexpected error in worker for App alarm_system:
2019-01-17 09:14:53.022261 WARNING AppDaemon: Worker Ags: {'name': 'alarm_system', 'id': UUID('e5c16be7-6835-4022-abe2-478e52a09324'), 'type': 'timer', 'function': <bound method AlarmSystem.camera_snapshot of <alarm.AlarmSystem object at 0x7485f030>>, 'kwargs': {}}
2019-01-17 09:14:53.023373 WARNING AppDaemon: ------------------------------------------------------------
2019-01-17 09:14:53.029082 WARNING AppDaemon: Traceback (most recent call last):
File "/usr/lib/python3.6/site-packages/appdaemon/appdaemon.py", line 586, in worker
funcref(self.sanitize_timer_kwargs(app, args["kwargs"]))
File "/config/appdaemon/apps/alarm.py", line 287, in camera_snapshot
self.log("Camera snapshot {} stored as {}".format(self._snap_count, filename))
UnboundLocalError: local variable 'filename' referenced before assignment
2019-01-17 09:14:53.030404 WARNING AppDaemon: ------------------------------------------------------------
in practice it happens just after activating alarm system … it makes the light flash for 40 seconds in pending time and then executes this command about camera_snapshot
I never received this error before this week…
ill think you find that problem with a lot of apps.
people write them mostly for themselves, and if it works for them they just use it and dont look at github. and if they stop using it they dont remove it, for obvious reasons.
