HASS OS: 2021.12.6
When I try and add NZBGet to Home Assistant I get the following error in the logs.
Is there something specific I need to set up in NZBGet?
File "/usr/src/homeassistant/homeassistant/components/nzbget/config_flow.py", line 92, in async_step_user
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/src/homeassistant/homeassistant/components/nzbget/config_flow.py", line 51, in validate_input
nzbget_api.version()
File "/usr/local/lib/python3.9/site-packages/pynzbgetapi/__init__.py", line 60, in version
return self.__proxy_call(lambda: self.proxy.version())
File "/usr/local/lib/python3.9/site-packages/pynzbgetapi/__init__.py", line 54, in __proxy_call
return method_call()
File "/usr/local/lib/python3.9/site-packages/pynzbgetapi/__init__.py", line 60, in <lambda>
File "/usr/local/lib/python3.9/xmlrpc/client.py", line 1116, in __call__
return self.__send(self.__name, args)
File "/usr/local/lib/python3.9/xmlrpc/client.py", line 1458, in __request
response = self.__transport.request(
File "/usr/local/lib/python3.9/xmlrpc/client.py", line 1160, in request
return self.single_request(host, handler, request_body, verbose)
File "/usr/local/lib/python3.9/xmlrpc/client.py", line 1172, in single_request
http_conn = self.send_request(host, handler, request_body, verbose)
File "/usr/local/lib/python3.9/xmlrpc/client.py", line 1285, in send_request
self.send_content(connection, request_body)
File "/usr/local/lib/python3.9/xmlrpc/client.py", line 1315, in send_content
connection.endheaders(request_body)
File "/usr/local/lib/python3.9/http/client.py", line 1274, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.9/http/client.py", line 1034, in _send_output
self.send(msg)
File "/usr/local/lib/python3.9/http/client.py", line 974, in send
self.connect()
File "/usr/local/lib/python3.9/http/client.py", line 945, in connect
self.sock = self._create_connection(
File "/usr/local/lib/python3.9/socket.py", line 823, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/usr/local/lib/python3.9/socket.py", line 954, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
