More logs:
Logger: homeassistant.util.loop
Source: util/loop.py:77
First occurred: 3:29:10 PM (1 occurrences)
Last logged: 3:29:10 PM
Detected blocking call to import_module with args ('homeassistant.components.influxdb',) in /usr/src/homeassistant/homeassistant/loader.py, line 1075: ComponentProtocol, importlib.import_module(self.pkg_path) inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#import_module Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.13/asyncio/base_events.py", line 707, in run_until_complete self.run_forever() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 678, in run_forever self._run_once() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2033, in _run_once handle._run() File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run self._context.run(self._callback, *self._args) File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in async_setup_component result = await _async_setup_component(hass, domain, config) File "/usr/src/homeassistant/homeassistant/setup.py", line 340, in _async_setup_component component = await integration.async_get_component() File "/usr/src/homeassistant/homeassistant/loader.py", line 1027, in async_get_component comp = self._get_component() File "/usr/src/homeassistant/homeassistant/loader.py", line 1075, in _get_component ComponentProtocol, importlib.import_module(self.pkg_path)
Logger: homeassistant.loader
Source: loader.py:1075
First occurred: 3:29:10 PM (2 occurrences)
Unexpected exception importing component homeassistant.components.influxdb
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 201, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/influxdb/__init__.py", line 15, in <module>
from influxdb import InfluxDBClient, exceptions
File "/usr/local/lib/python3.13/site-packages/influxdb/__init__.py", line 10, in <module>
from .dataframe_client import DataFrameClient
File "/usr/local/lib/python3.13/site-packages/influxdb/dataframe_client.py", line 12, in <module>
import pandas
File "/usr/local/lib/python3.13/site-packages/pandas/__init__.py", line 138, in <module>
from pandas import api, arrays, errors, io, plotting, tseries
File "/usr/local/lib/python3.13/site-packages/pandas/api/__init__.py", line 2, in <module>
from pandas.api import (
...<5 lines>...
File "/usr/local/lib/python3.13/site-packages/pandas/api/typing/__init__.py", line 31, in <module>
from pandas.io.json._json import JsonReader
File "/usr/local/lib/python3.13/site-packages/pandas/io/json/__init__.py", line 1, in <module>
from pandas.io.json._json import (
...<4 lines>...
File "/usr/local/lib/python3.13/site-packages/pandas/io/json/_json.py", line 71, in <module>
from pandas.io.parsers.readers import validate_integer
File "/usr/local/lib/python3.13/site-packages/pandas/io/parsers/__init__.py", line 1, in <module>
from pandas.io.parsers.readers import (
...<5 lines>...
SyntaxError: source code string cannot contain null bytes
Logger: homeassistant.setup
Source: setup.py:340
Setup failed for 'influxdb': Unable to import component: Exception importing homeassistant.components.influxdb
import pandas
...<5 lines>...
...<4 lines>...
...<5 lines>...
File "/usr/src/homeassistant/homeassistant/loader.py", line 1015, in async_get_component
comp = await self.hass.async_add_import_executor_job(
self._get_component, True
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1086, in _get_component
raise ImportError(f"Exception importing {self.pkg_path}") from err
ImportError: Exception importing homeassistant.components.influxdb
import pandas
...<5 lines>...
...<4 lines>...
...<5 lines>...
File "/usr/src/homeassistant/homeassistant/loader.py", line 1035, in async_get_component
self._component_future.result()
