Unexpected exception - Websocket API error with Gree HVAC
I’ve been struggling with Gree AC integration for months. The official integration works fine, but it shows target temperature as AC’s temperature read, which doesn’t allow me to use some automations. Thankfully HomeAssistant-GreeClimateComponent allows to add external temp sensor to climate entity.
I can’t get it to work, because every time I interact with Gree through HA I get timeouts. Furthermore, the Websocket error is displayed. I was suggested that it has to do with my version rollbacks, but as I checked it is also thw problem in a clean installation. I’m sending logs in the attachments. Could you please help me resolving the problem?
Best regards,
Jakub
Rejestrator: homeassistant.components.websocket_api.http.connection
Źródło: components/websocket_api/commands.py:241
integracja: Home Assistant WebSocket API (dokumentacja, Problemy)
Pierwsze zdarzenie: 16:43:17 (1 zdarzenia)
Ostatnio zalogowany: 16:43:17
[139670138042496] Unexpected exception
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 241, in handle_call_service
    response = await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 2763, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2806, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 999, in entity_service_call
    single_response = await _handle_entity_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1071, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 758, in async_set_hvac_mode
    await self.hass.async_add_executor_job(self.set_hvac_mode, hvac_mode)
TimeoutError: timed out
