Updated: I am a technology user (as oppose to a developer or general tech demi-god) and I need a bit of advice of how to track down the cause of an event. For unexplained reasons, my garage door was triggered by MQTT. I have the device sending diagnostic to a Syslog server resulting in:
Aug 19 19:07:27 GarageDoor-0550 ESP-SRC: MQTT
Aug 19 19:07:27 GarageDoor-0550 ESP-CMD: Grp 0, Cmd ‘POWER’, Idx 1, Len 2, Pld 1, Data ‘ON’
Aug 19 19:07:27 GarageDoor-0550 ESP-MQT: stat/GarageDoor/RESULT = {“POWER”:“ON”}
Aug 19 19:07:27 GarageDoor-0550 ESP-MQT: stat/GarageDoor/POWER = ON
The garage door has no automation other than the dashboard/mobile button to open or close the garage door and sending a notification when an opening occurs. Nothing else is set up. It has worked great for over a year without incident. The device is a Shelly 1 running which was running Firmware: 9.5.0 for over a year. I have since upgraded to 12.0.2 and still have the same problem. The problem began shortly after upgrading HA (I have since upgrade twice more).
The Logbook simply shows:
Tasmota_garage turned on 7:07:27 PM - 17 hours ago
Any advice on the next steps of analysis?
Home Assistant 2022.8.6
Supervisor 2022.08.3
Operating System 8.4
Frontend 20220802.0 - latest
From the log:
|9:26:38 PM - Yesterday|switch.tasmota_pier on|
|9:26:39 PM - Yesterday|switch.tasmota_pier off|
|9:26:39 PM - Yesterday - Supervisor|Garage Door was opened triggered by service cover.close_cover|
|9:26:39 PM - Yesterday|Garage Door State was opened|
|9:26:39 PM - Yesterday - Show trace|Garage Door Now triggered by state of Garage Door State was opened|
|9:27:18 PM - Yesterday|Bedor Garage Door was opened|
|9:27:33 PM - Yesterday|Garage Door was closed|
|9:27:33 PM - Yesterday|Garage Door State was closed|
There is a state feedback (from a reed switch integrated into the Shelly) that then triggers a notification to my phone that the door has been opened.
I caused the door to close.
No idea what caused the Shelly/Tasmota switch to fire.
My guess is the problem is most likely an HA issue since the Tasmota switch has been running perfectly for a year and I always keep HA to the latest version. I have turned on turned on logging in the Tasmota device but I need some help understanding the log. Somehow the device is triggering or HA is causing it to be triggered.
