I’m trying to use emoji in telegram messages but i don’t find the correct syntax to do that.
I have tried (without result):
- \u1F512
- \u1F512
what should be the correct syntax?
Thanks!
Thanks!
I get it using unicode format like this:
message: “\U0001F420 BLABLABLABLA”
You can find the codes here:
http://unicode.org/emoji/charts/full-emoji-list.html
This works fine for me when using it in an automation like this
- service: notify.telegram
message: "\U00002714 Here goes my message"
but I cannot get it to work when using a data template
- service: notify.telegrambot
data_template:
message: 'Here goes my message'
I’ve tried using ’ and " and whatever stuff ({{}}, UTF-16 etc) mentioned in Emojis in iOS notifications - #12 by patfelst.
Ideas?
dosen’t look like i’m able to do that even in automations…
- data:
message: 'Drin - Drin! \U0001F514'
not working
edit: actually, it works but only at the beginning of the string.
- data:
message: '\U0001F514 Drin - Drin!'
A think to open an issue about this it would be a good idea.
Did you find a solution to send unicode emjis in templates?
I’ve tested this and ist seems to be working:
message: "\uD83D\uDD0C Power cord is not plugged! \uD83D\uDE14"
This works:
- service: notify.admin_group
message: >
{%- if trigger.to_state.state == 'armed_away' -%}
{{ "Alarm is armed (away) \U0001F534" }}
{%- elif trigger.to_state.state == 'armed_home' -%}
{{ "Alarm is armed (home) \U0001F7E1" }}
{%- elif trigger.to_state.state == 'disarmed' -%}
{{ "Alarm is disarmed \U0001F7E9" }}
{%- elif trigger.to_state.state == 'arming' -%}
{{ "Alarm is arming \U0001F7E8" }}
{%- else %}
{{ "Alarm is *{{ trigger.to_state.state }}*" }}
{%- endif -%}
