Unifi Add-on unavailable
I am having trouble starting the Unifi Add-on lately. Sometime after some random restarts of home assistant it will start again, but not always. How can I troubleshoot this problem. I think it is since Unifi 0.13.5
Host 3.11, and also same problem on 3.9
RaspberryPi 3b+
Home assistant 0.105 and up to 0.105.5
log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: UniFi Controller
 Manage your UniFi network using a web browser
 Add-on version: 0.13.5
 You are running the latest version of this add-on.
 System: HassOS 3.11  (armv7 / raspberrypi3)
 Home Assistant version: 0.105.5
 Supervisor version: 201
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to DEBUG
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] unifi.sh: executing...
[15:02:02] DEBUG: Injecting SSL certificate into the controller...
[15:02:02] DEBUG: Preparing certificate in a format UniFi accepts...
[15:02:02] DEBUG: Removing existing certificate from UniFi protected keystore...
[15:02:03] DEBUG: Inserting certificate into UniFi keystore...
Importing keystore /tmp/tmp.TIQYSrgNXG to /usr/lib/unifi/data/keystore...
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using "keytool -importkeystore -srckeystore /usr/lib/unifi/data/keystore -destkeystore /usr/lib/unifi/data/keystore -deststoretype pkcs12".
[cont-init.d] unifi.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[15:02:05] INFO: Starting the UniFi Controller...
