Hoping for some help, maybe it’s a version thing, but my device tracking has completely stopped working.
I have the following setup:
HASS 0.95.4 running on ArchLinux (fully patched)
Unifi controller 5.10.25 running on Windows (Unifi Gateway, 3x Unifi APs, Unifi Switch connected)
I have enabled verbose logging in configuration.yaml
logger:
default: info
# added to debug unifi connections:
logs:
aiounifi: debug
homeassistant.components.unifi: debug
homeassistant.components.switch.unifi: debug
When I (re)start home assistant, I can see in the logs that it connects fine to the unifi controller, and dumps a LOT of information, including all the details of all connected devices.
The unifi account is a full admin, and I can also login to the controller web interface and view everything using this account.
Weirder still, is that this configuration has worked in the past, I have had a known_devices.yaml file and been able to edit that with no issues, however now when I move/rename the known_devices.yaml and restart hass, it doesn’t come back at all. I see (via the documentation) that known_devices.yaml is being phased out as of 0.94, (but replaced by what?) is that my issue?
It’s as if device tracking isn’t even enabled - and yet it does connect to the controller using the settings specified under device_tracker.
There are also no errors in the logs (set to info).
I’m currently using the config below, however have tried with only the required options enabled, and it makes no difference that I can see (as nothing at all is being tracked).
Configuration.yaml:
device_tracker:
- platform: unifi
username: !secret unifi_user
password: !secret unifi_password
host: 192.168.11.3
#port: 8443
#site_id: default
verify_ssl: false
detection_time: 180
interval_seconds: 12
consider_home: 180
monitored_conditions:
- last_seen
- hostname
- ip
- name
new_device_defaults:
track_new_devices: true
