Anyone using the unifi controller on docker, and knows if it allows you to know if a device is connected to a specific AP?
The actual controller page will tell you this via the devices list or more visually on the map.
I don’t believe this data is passed to the Unifi Controller based integration.
edit: wrong info see fanaticdavid’s response below.
This integration (which uses the actual AP for data) would provide what you are looking for. However, it wouldn’t tell you if the device is on another AP unless you set that one up also.
