Hey all, I’m having trouble setting up Unifi as a device tracker. I’ve tried every solution provided for similar problems on the forums but without luck so far. I’m pretty clueless, maybe someone can help?
I’m running HA on a RasPi 3 using HassIO, and the Unifi Controller on a separate RasPi Zero W. Both are working correctly and are visible on the same subnet. After setting up it didn’t create a known_devices.yaml, but it did when I did a “see” from the services panel. It found my iPhone after providing only the mac address.
The error in the logs that I’m getting is this:
2017-08-18 18:26:35 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform unifi
File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 386, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 382, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.6/http/client.py", line 1331, in getresponse
response.begin()
File "/usr/lib/python3.6/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.6/http/client.py", line 266, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 438, in send
timeout=timeout
File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/util/retry.py", line 357, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3.6/site-packages/requests/packages/urllib3/packages/six.py", line 685, in reraise
raise value.with_traceback(tb)
chunked=chunked)
response.begin()
requests.packages.urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 153, in async_setup_platform
platform.get_scanner, hass, {DOMAIN: p_config})
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/unifi.py", line 52, in get_scanner
site_id=site_id, ssl_verify=verify_ssl)
File "/usr/lib/python3.6/site-packages/pyunifi/controller.py", line 89, in __init__
self._login(version)
File "/usr/lib/python3.6/site-packages/pyunifi/controller.py", line 148, in _login
r = self.session.post(login_url, params)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 565, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 518, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 639, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 488, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response',))
