I’m getting an error after home assistant restarts and can not get unifi to see my devices
log:
Error setting up platform legacy
File “/usr/local/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py”, line 472, in wrap_socket
cnx.do_handshake()
File “/usr/local/lib/python3.7/site-packages/OpenSSL/SSL.py”, line 1915, in do_handshake
self._raise_ssl_error(self._ssl, result)
File “/usr/local/lib/python3.7/site-packages/OpenSSL/SSL.py”, line 1647, in _raise_ssl_error
_raise_current_error()
File “/usr/local/lib/python3.7/site-packages/OpenSSL/_util.py”, line 54, in exception_from_error_queue
raise exception_type(errors)
OpenSSL.SSL.Error: [(‘SSL routines’, ‘tls_process_server_certificate’, ‘certificate verify failed’)]
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 603, in urlopen
chunked=chunked)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 344, in _make_request
self._validate_conn(conn)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 843, in validate_conn
conn.connect()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 370, in connect
ssl_context=context)
File "/usr/local/lib/python3.7/site-packages/urllib3/util/ssl.py", line 368, in ssl_wrap_socket
return context.wrap_socket(sock)
File “/usr/local/lib/python3.7/site-packages/urllib3/contrib/pyopenssl.py”, line 478, in wrap_socket
raise ssl.SSLError(‘bad handshake: %r’ % e)
ssl.SSLError: (“bad handshake: Error([(‘SSL routines’, ‘tls_process_server_certificate’, ‘certificate verify failed’)])”,)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 641, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 399, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘192.168.1.101’, port=8443): Max retries exceeded with url: /api/login (Caused by SSLError(SSLError(“bad handshake: Error([(‘SSL routines’, ‘tls_process_server_certificate’, ‘certificate verify failed’)])”)))
File “/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py”, line 69, in async_setup_legacy
self.platform.get_scanner, hass, {DOMAIN: self.config})
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/unifi/device_tracker.py”, line 73, in get_scanner
site_id=site_id, ssl_verify=verify_ssl)
File “/usr/local/lib/python3.7/site-packages/pyunifi/controller.py”, line 89, in init
self._login()
File “/usr/local/lib/python3.7/site-packages/pyunifi/controller.py”, line 137, in _login
r = self.session.post(login_url, json=params)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 581, in post
return self.request(‘POST’, url, data=data, json=json, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 514, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host=‘192.168.1.101’, port=8443): Max retries exceeded with url: /api/login (Caused by SSLError(SSLError(“bad handshake: Error([(‘SSL routines’, ‘tls_process_server_certificate’, ‘certificate verify failed’)])”)))
configuration:
device_tracker:
- platform: unifi
host: 192.168.1.XXX
username: ! secret unifi_username
password: ! secret unifi_password
verify_ssl: True
site_id: default
detection_time: 60
track_new_devices: yes
ssid_filter:- ‘XXXXXXXXX1’
- ‘XXXXXXXXX2’
any idea why i’m getting this error ??? the integration worked in the past but not anymore.
please help
