Can anyone offer any advice on what’s going on here?
I’m trying to use the Unifi integration for presence detection by detecting when our phones connect to our wifi network.
I’m 90% sure I have the config right but when I restart HA (Hass.io) I see the error below in the logs.
Full log below shows issues with connection.py file.
I’m lost at this point, any help would be appreciated…
Log Details (ERROR)
Sun Apr 21 2019 11:11:55 GMT+0800 (Australian Western Standard Time)
Error setting up platform unifi
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 80, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 70, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f8224b3c8>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.1.24', port=8443): Max retries exceeded with url: /api/login (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f8224b3c8>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/device_tracker/__init__.py", line 177, in async_setup_platform
platform.get_scanner, hass, {DOMAIN: p_config})
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/unifi/device_tracker.py", line 80, in get_scanner
site_id=site_id, ssl_verify=verify_ssl)
File "/usr/local/lib/python3.7/site-packages/pyunifi/controller.py", line 89, in __init__
self._login()
File "/usr/local/lib/python3.7/site-packages/pyunifi/controller.py", line 137, in _login
r = self.session.post(login_url, json=params)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 581, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
configuration.yaml
sensor: !include sensors.yaml
group: !include groups.yaml
script: !include scripts.yaml
cover: !include cover.yaml
scene: !include scenes.yaml
device_tracker: !include device_tracker.yaml
device_tracker.yaml
- platform: unifi
host: 192.168.1.24
username: !secret ubiquiti_username
password: !secret ubiquiti_password
verify_ssl: false
detection_time: 60
ssid_filter:
- '[MY SSID]'
EDIT:
So, device tracker seemed to work for a short period then stopped.
Now only getting this error:
Log Details (ERROR)
Sun Apr 21 2019 12:05:07 GMT+0800 (Australian Western Standard Time)
Error doing job: SSL handshake failed
File "uvloop/sslproto.pyx", line 500, in uvloop.loop.SSLProtocol._on_handshake_complete
File "uvloop/sslproto.pyx", line 484, in uvloop.loop.SSLProtocol._do_handshake
File "/usr/local/lib/python3.7/ssl.py", line 763, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN] sslv3 alert certificate unknown (_ssl.c:1056)
