I’m coming over from Domoticz to Home Assistant and what a relief .
I get all my sensors working except for 1 and that is the unifi controller web app.
When i tried to install this, it works but after few minutes the whole system doesn’t respond anymore. Then I need to make a clean install and start over again.
I’m on the latest Home Assistant Operating System for RPI 3B+ (64bit) with the addon for Unfi directly from Home Assistant.
I’m just guessing here but I’d think that the controller is probably resource hungry and a 3b is having trouble keeping up. Do you have a memory and cpu sensor set up? Is there any spike?
You can enable them by adding sys mon to your config
Honestly, I would just download the version that can run on a PC. Then you can use the Unifi Network integration in HA to connect to it and get device trackers and all that fun stuff.
Alternately, get a UDM Pro or SE. WELL worth the money. If I had it to do over, I’d get the SE, but that wasn’t out when I bought my Pro.
